MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > Other Cars
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 02-08-2006, 01:36 PM
TheDude's Avatar
G vs cobra
simple question...I hope. How much different is the G coupe RWD system from an 01 cobra? 01 cobra has traction control and IRS (independant rear suspension)??
Is one better or worse??
Old 02-08-2006, 01:39 PM
My mommy says I'm cool.
2005 Infiniti G35 Coupe
I think the 01 cobras had the IRS that wasn't all that good. It allowed for too much wheel hop so launching it was a task.
However, the suspension on the cobra is softer than the G so I would assume you could launch the cobra a bit harder than the G.
Old 02-08-2006, 01:41 PM
what's the question?
They are work the same. Drive shaft into a limited rear slip. then out to the two wheels.
Are you looking for gear ratios? Strength differences?
Old 02-08-2006, 02:18 PM
Send a message via ICQ to vasqo Send a message via AIM to vasqo Send a message via MSN to vasqo
i thought the mustang/cobras where with a live axle in the back which is better only if u r doing 1/4 mile drag....
__________________
"If life passes you buy, downshift and floor the motherphuqer!"
Old 02-08-2006, 02:36 PM
TheDude's Avatar
mustangs are a solid axel 01+ cobras are IRS...
The question is which is a better system handling wise, slalom wise etc.
Old 02-08-2006, 05:18 PM
^^ really? humm if thats the case .... i am pretty sure that IRS is much more adeaute on the twisties... where as the solid axel is for strength... ie trucks!
__________________
Old 02-08-2006, 10:40 PM
Send a message via AIM to Ts916G35 Send a message via MSN to Ts916G35
i dunno about 01 Cobra.
but i know the 03 one are "FAST"
Old 02-08-2006, 11:31 PM
TheDude's Avatar
heh i'm not questioning the speed of them, I had an 01 cobra and it was cool and quick but not as fast as the 03\04, the G could probably run w\ my 01.
Old 02-09-2006, 12:49 AM
Quote:
handling wise the IRS is superior to the live axle.
Drag wise, well, it depends on the set up.
Conventional wisdom and history says the live axle is better for
drag racing (less wheel hop) but there are an awful lot of IRS cars
that make a lot of horsepower that do REALLY well at drag racing too.
Ford's own Cobra as you were mentioning, and the Ford GT itself is
a FAST car out of the gate...same with the new Corvette ZO6.
They all have IRS on them and do just fine at the drags.
Comparing the 01 Cobra's IRS to the G's...well that's beyond my knowledge
as to which is a better set up.
I personally would prefer a well set up IRS to the live axle.
But the live axle in the new Mustang GT is not too bad...and to keep costs
down Ford's using an even more modified version of that live axle
in the Cobra's replacement...the Shelby GT500.
Will have to wait to see how it does, many are upset about that though and wished Ford would of spent the extra money to put the IRS in the GT500.
Ford claims it would of meant a total repackaging of the Mustang's rear.
Old 02-09-2006, 12:59 PM
Send a message via AIM to nhazra Send a message via MSN to nhazra
The Cobra had 320hp and 317lb-ft torque weighing in at 3430 lbs. Technically the Cobra should be a little faster than the G.
Old 02-10-2006, 10:04 AM
Well according the reviews, the cobras stock suspension is too soft making it handle rather poorly and was prone to wheel hop.
But if you are looking to go aftermarket there are 200 times as many options as there are with the G.
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
