  #151
Old 03-29-2008, 01:26 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by da mayor
still want to try and go more aggressive w/ a 10.5 and 40mm offset...
ahh.. c'mon Kenny... do a 10.5 +35 with a 255/35 and you'll be the man. I wanna do 9/10 +25 all around
  #152
Old 03-29-2008, 08:48 AM
da mayor's Avatar
im trying to do some rim shopping but it's been impossible w/ work. i got 14 people picking up new cars today alone ...
and last time i had a +38 w/ a 20x8.5 rim it rubbed
  #153
Old 03-29-2008, 08:52 AM
Ralph0064's Avatar
*ouch* that accord looks like dooo-dooo in the rear
  #154
Old 03-29-2008, 09:03 AM
G35SHAWN's Avatar
My upcoming set up definetly going for that stretch look.
  #155
Old 03-29-2008, 11:16 AM
FlyingLumpia's Avatar
da mayor, I just put a +10mm so right now I am at +30 on a 20x8.5. Surely I am not as low as you but it can be done. I am actually going to get a 15mm to make it +25.
  #156
Old 03-29-2008, 03:36 PM
CreativeDesignZ's Avatar
i think u should add a BBK to the mix of being agressive. seeing some of these setups with regular brakes just totally takes away from the look of aggressiveness
  #157
Old 03-29-2008, 04:55 PM
that would be an aggressive OVERALL look. This thread is solely for aggressive wheel and tire setup's.
-GP-
  #158
Old 03-29-2008, 04:56 PM
Lemme know what wheels you want and i'll find them in the right size and offset for you bro!
The only reason your +38 rubbed is cause the tire was too wide and you didnt have enough negative camber
-GP-
  #159
Old 03-29-2008, 11:45 PM
Algy's Avatar
I dont know if it has been done or if it would look good.... BUUUUUUUUUUUUUT
Has anyone tried putting on spacers on the OEM 19s and having stretched tires on them to give that aggressive look?
OR would that just look stupid?
  #160
Old 03-29-2008, 11:51 PM
redlude97's Avatar
You can't get spacers wide enough that would necessitate stretched tires, you would need something like a 40-50mm spacer
  #161
Old 03-30-2008, 04:14 PM
Sylvan lake V35's Avatar
HRE comp 21s 19x10.5 +17 w/265 fronts 19x12 +22 w/285. I will have some new pics with the barrels painted DG in a day or two.
Attached Thumbnails Aggressive Wheels & Stretched Tires: Post 'Em Up! [[Some NSFW]]-copy-dsc01512.jpg   Aggressive Wheels & Stretched Tires: Post 'Em Up! [[Some NSFW]]-copy-dsc01506.jpg   Aggressive Wheels & Stretched Tires: Post 'Em Up! [[Some NSFW]]-copy-dsc01505.jpg
  #162
Old 03-30-2008, 06:41 PM
sugsss's Avatar
^^^is this the old setup from that red g,looks fackin good wish I went 10.5/12
with my new setup.
  #163
Old 03-30-2008, 07:34 PM
with my new setup.
Thanks
I just had them painted to mach the cars body color just waithing to get the tires on and I will get some more pics up.
  #164
Old 03-30-2008, 08:54 PM
Cost a G's Avatar
Sylvan, Madd width on those wheels mang. Wish your car had a lower drop though. Slam it !!
  #165
Old 03-30-2008, 10:00 PM
I just got these wheels and bolted them on for a test fit snapped a few pics. Took them off and painted them when I put them on I will see if I can go any lower without rubbing the front fenders.
Quick Reply: Aggressive Wheels & Stretched Tires: Post 'Em Up! [[Some NSFW]]
