DIY: Airbag Reset Instructions for 03-07 G35 Coupe
Rating: Thread Rating: 4 votes, 4.75 average.
  #166
Old 09-24-2014, 10:08 AM
hotstrick's Avatar
worked
Worked like a charm dis it 3 times 05 g35 coup 6mt ty
  #167
Old 10-29-2014, 12:38 AM
Salndemi's Avatar
03 sedan airbag light
Originally Posted by minh
will this work for 03 sedan?
Yes it does work on 03 sedan, worked perfectly on mine.
  #168
Old 11-11-2014, 04:09 PM
djcandle's Avatar
Great fix and worked to a tee, but foes this trick also affect the factory alarm by chance? My alarm has been randomly going off ever since this fix.
Even stranger is when I plug the key into the ignition to try and turn it off, it does nothing but honk.
I can drive away with the car alarm still going off.
  #169
Old 03-05-2015, 03:47 PM
riceeeeeeeeee's Avatar
I had a local shop clear the code after I hit my washer and moved the washer about an inch from impact. No scratches/dents on the car but the light came back flashing 5 days later any comments on what to do next? The guy ran the code as rear passenger module.
  #170
Old 05-17-2015, 07:39 PM
ProBballChamp's Avatar
This worked like a charm for me for my 03 Sedan. At first I was skeptical for the "Wait till it blinks of then turn it off ( and repeat)", but now the light is gone. Thanks!
  #171
Old 06-07-2015, 10:16 PM
JohnnysG35's Avatar
Yup this totally works i
I switched my seats out on my g35. And when I turned the car on what do you know the dam airbag light is blinking haha.
  #172
Old 07-17-2015, 09:19 PM
nissan54's Avatar
I have been trying to fix the air bag warning light for years. The reset works fine saves me a trip to the repair shop. I still have a niggling feeling that we have fixed the symptom not the cause.
Thanks for the tip, at least that distracting flashing light is out of my face.
Cheers
  #173
Old 10-04-2015, 11:16 AM
AMAYA092009's Avatar
Its workss
Originally Posted by SFLG35
this is a little easier
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
Tried the first method failed. The second method works like charm.
  #174
Old 10-07-2015, 12:09 PM
SAMzG35's Avatar
G35
  #175
Old 10-15-2015, 11:49 AM
Darr707's Avatar
Thanks!
Omg, this worked perfectly. I changed cabin air filter and then the bag icon flashed nonstop. Was worried I messed up a wire or something. Glad you guys are on here.
  #176
Old 11-01-2015, 10:48 AM
Corsair's Avatar
I have 2005 G35x and this tip has been helpful. Only problem is the light kept coming back for me after a few days.
Took it to a local mechanic and he read the code and said it was a front right door module fault. Unfortunately he couldn't do anything about it. Called a dealer to see and they told me if I go in and decide not to do any work that theres a 190$ fee just to be able to leave the place! Crazy. So I think I'll keep resetting the light for now since its not a front air bag problem.
  #177
Old 02-25-2016, 12:20 PM
CharlieTad's Avatar
Thumbs up
Thanks a Ton friend , I just got my 2003 Infiniti G35 Sedan , Airbag Light Blinking resolved with the said Instruction , happy to have joined this forum. Hope it does not return back
  #178
Old 02-26-2016, 11:33 AM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
This worked for me when I changed out my seat for cleaning.
Urban.
  #179
Old 03-16-2016, 09:40 PM
medianjoe's Avatar
The light came back every day. I disconnected the airbag connector under the driver seat, sprayed WD40, connected back, and zip-tied the connector. It solved the issue.
Attached Thumbnails DIY: Airbag Reset Instructions for 03-07 G35 Coupe-airbagconnector.jpg
  #180
Old 04-19-2016, 10:29 PM
utkarsh_lemons's Avatar
confused
i did this whole process and it went away for like a week then came back, i did it again and it went away then came back a couple hours later do i need a new sensor or what?
can anyone help
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
Quick Reply: DIY: Airbag Reset Instructions for 03-07 G35 Coupe
