MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > Engine, Drivetrain & Forced-Induction > Reviews
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 08-11-2006, 12:04 PM
TS ECU & Z-tube
First of all, I already had the MREV+, headers (coated) and cats installed before the Z-tube, so the tube's sudden pressence is certainly known! The induction growl that now accompanies the MREV/header/cat sound is incredible. I might one day consider going to a really nice C/F z-tube (smooth inside, etc.) just for the added resonance. Then again, the OEM look of the Z-tube works well for me too. Also installed the NISMO drop-in filter and it seems to compliment the Z-tube and MREV+ just fine.
After the MREV+, headers and cats were installed, the car felt rich below 2500rpm, but everything seemed right at 3000rpm and above. After the TS F-Spec reflash, the a/f does feel a bit better in that range. But the big improvement is still above 3000rpm. When the MREV kicks at 4000rpm, I can feel some additional power and everything seems to be running just as it should. I haven't taken it to redline since the install, but it sure as h*ll has been pulling nicely through 5500rpms. The induction and exaust growl above 4000rpm is a bit addictive... ...and the car sounds like a mean MF'er now instead of just having some minor exhaust mod.
The other cool thing about getting the reflash is that it pretty much rounds-out my mod plans. I still have brake lines/pads and the clutch/flywheel, etc. to install, as the OEM pieces begin to take a dive. Aside from those, I'm down to just wheels/tires and the CF driveshaft that I've been contemplating.
__________________
'05 6MT Coupe - IP/Stone: NIMSO Front Bumper, KarumaZ Diffuser, Gialla, DS Rear Spoiler, MREV+, NISMO Headers, Crawford Cats, NISMO Sway Bars.
Old 09-21-2006, 04:42 PM
I assume you sent your ecu in? Since they are custom flashes, didn't you need to dyno or datalog your a/f ratios before? Therefore shouldn't you actually know if the a/f was rich/lean at xxxx rpm?
Thanks
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks *meow*
Quote:
Originally Posted by dirrtybear
If they bailout the big 3 automakers, I'm moving overseas.
Quote:
Originally Posted by Jeff92se
So you decided on a country yet?
Old 09-21-2006, 05:30 PM
Yes, I would have needed to send at least a dyno sheet with a/f readings if I wanted them to make specific changes relative to my specific readings.
__________________
Old 09-28-2006, 12:51 PM
what warranty issues does reflashing bring up. I see that your G is an 05', and i read somewhere else that the dealership asked if the ecu was reflashed. For this reason i'm worried about getting a TS reflash, I'm leaning more to the side of the UTEC, or other piggyback emu.
__________________
06' 6MT - Stillen Cold Air w/ Z-Tube // Seibon OEM Carbon Fiber Hood // Carbon Fiber Gialla Corsa Style Grill // Tein 350z H-Techs // M1's wrapped in Toyo T1R's - 19x8.5 (255/35/19) and 19x10.5 (275/35/19) // Crawford HFC // HKS Hi-power TI Exhaust. // Richie Strut Bar // BlueBat Overlays //
Old 09-28-2006, 12:57 PM
I don't understand. You apparently didn't send in a/f ratio data but TS was able to give you a F-spec reflash that includes ign/fuel adjustments?
Or did TS give you a reflash that is based on other cars that have similar mods? ie... flashing with an existing map they already have?
Thanks.
Quote:
__________________
Old 09-28-2006, 01:05 PM
trey.hutcheson's Avatar
Who is Tarjan?
^^^ Utec can be easily removed, and the Cobb handlheld tuner can flash back to stock.
__________________
05 6MT Sedan. stock airbox, ztube, mrev, ichiba headers, kinetix pipes, stillen gen1 catback, Clutchmasters Stage1+JWT Fly, utec tuned by sharif + BFG's = 13.264@103.96mph in 975 feet DA
Old 09-28-2006, 04:54 PM
Jeff - Yes, my understanding is that they have a base-tuned map for just such a scenario. While my tune could be improved, I really had to settle for simply a better tune than I had with the OEM ECU and my mods. And, of course, the other changes TS does (s-spec) are beneficial as well. Send your a/f sheet (or car) to TS if possible.
jdmeg - TS doesn't do anything visual to the ECU, and it's not detectable with the dealers diagnostic equipment, so it's fairly transparent in terms of normal maintenance and repairs.
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
