MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > Engine, Drivetrain & Forced-Induction > Reviews
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 01-24-2007, 03:54 AM
drsifu1's Avatar
PWR High Capacity Radiator - Install Review
Vendor: SGP Racing (8/10 for customer service)
Product: PWR High Capacity Radiator geared towards FI
Price: $540 shipped
Availability: After this review....you may not what it
The install was a BITCH!!!!
Where do I start...
The 1st radiator I got had some very nice welds and looked tremendous, the only problem was that the threads on the 2 bungs that bolt the fan to the radiator were not made for OEM bolt. After trying to make it work, I busted one of the bungs and had to re-ship it back to SGP Racing so they could send me a new one.
The second one was also nice, but again, the bungs had not been re-threaded and again, did not match the OEM bolts. I went and got M6 x 1.0 mm bolts since I was told this was the thread size, but the threads are actually designed for M5 x 0.8 mm threads. Not having known this, I tried re-tapping the thread with an M6x1.0mm tap and ended up snapping a bolt when I tried bolting it on (i suck at tapping holes).
Pic of the bolts...do note you should get the right length bolts. Some large washers might help as well.
Where the two bolts get installed.
Another issue was that the holes were not lined up. One was higher than the other by 1/4" or so. I think PWR has some issues with these two particular bungs
After getting this issue resolved, I went to install the radiator.
Again, there were some alignment issues with this radiator. The supports on the bottom were about 1/4" too close to each other (fixed that problem with a dremel and notching the radiator support so that they matched the supports on the radiator).
The other two bungs that attach the radiator to the A/C condenser did not line up. Again, I used a dremel to notch out the bracket on the A/C condenser so the holes would line up with the radiator. Only need to do one side of course.
The good news is that this radiator will clear and fit without any modifications to the fan. There is about 1/2"-1" clearance between the fan shroud and the belts. About 1/2" clearance with the coolant hose from the engine to the bottom of the radiator.
So if you plan on having this installed by a shop, than it might be a good buy. If you are a DIY, than be prepared for extra work.
I expected this piece to be simple plug and play. All the bolts and what not would fit like a glove and install rather easily. I was surprised that this is not the case.
Old 01-24-2007, 09:29 AM
BrianlG35C's Avatar
Thanks for the very detailed review. This definitely makes me reconsider a purchase.
__________________
510whp & 500wtq@14psi, APS TT, Built Motor, Exedy Twin Disc Clutch, Greddy EVO TT, Bilstein Coilovers, Stillen Sways, Modified KenStyle Kit & DPE R16s
Old 01-28-2007, 02:20 PM
welcome to the world of tuning. nice radiator
__________________
04' 6mt desert platinum w/BREMBO package stillen hfab/utr c/f z-tube/350z c/f eng. cover/s/s clutch line/ jdm rhd battery cover/utr c/f batt covers/stop tech slotted rotors/endless pads/MD 1/2 iso- spacer..to be continued..
Old 01-28-2007, 02:26 PM
Nismo G's Avatar
Bradenton, Fl
im sure he of all people needs to be welcomed into the world of tunning...
-sean
__________________
2003 OB 5AT G35 coupe -|- Apexi S-AFC II -|-Injen CAI -|- Motordyne 5/16" Spacer -|- Stillen Dual Cat-Back -|- Stillen Engine Damper -|- Tein CS coilovers -|- Tein EDFC -|- 19" Volk TE37 -|- 1/4 mile = 13.86 at 100.4 (no damper or suspension) -|-
Old 01-28-2007, 02:57 PM
ttrank's Avatar
TIMMAHH!!
Great write up. Thank you.
__________________
ONE FUN SEDAN!! MY CAR (LINK)
Rotora (12pot) 20" IForged Quad Projector Retro Greddy Twin Turbo + Built Motor by UMS Tuning = 600HP Sedan
Custom Dual 3" Twin Muffler Exhaust by Nichols AutoFab
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
