Reviews Reviews of specific modifications, posted by members
MREV2 + Motordyne 5/16" spacer! What a combo!!!!!!!!!!!
Old 02-11-2014, 08:27 PM
chrisconrey's Avatar
Is the gain from the mrev worth it or would it be smarter to invest that in exhaust or test pipes or some other Bolt on
  #107
Old 02-11-2014, 08:38 PM
MaDMaXX's Avatar
That's kind of a 'hmm' question for the DE. I think it's worth it, as it's all under the curve and throughout the rev range, but if you want an exhaust, i'd get that first.
  #108
Old 02-11-2014, 11:34 PM
So the mrev would bring more than just a 2-3hp increase alone as long as I had a 5/16 ISO right haha? Also would you advise an intake or leave it with the oem intake? And I appreciate the advice dude!
  #109
Old 02-11-2014, 11:40 PM
MaDMaXX's Avatar
Look at the gains under the curve, not the peak number (which i believe is the 2-3 you're seeing)
As yours is also an auto, you'll benefit a little more (not in actual figures) just in driveability, anything that gives you increases 'under the curve' makes it feel good during general driving.
You don't need the spacer to gain with the DE motor, but you will of course get the best gains from the pairing. You will get most from the spacer Vs the lower (MREV2) they do both stack on the DE.
Intake, the G35 isn't as good as the 350z, as for aftermarket intakes, i personally think you're not gaining anything without losing filtration with most of the after market solutions. If you can get a 350z intake, that's your best bet.
  #110
Old 02-11-2014, 11:45 PM
Wow I really appreciate that man! Does the conversion require any other parts?
  #111
Old 02-11-2014, 11:46 PM
And any specific year z?
  #112
Old 02-11-2014, 11:48 PM
MaDMaXX's Avatar
I can't help you with that one i'm afraid, i think it might be just the tube and perhaps the filter box, but i'm sure there is a guide here on G35driver for it. I think it will be the same years before it went dual intake, pre 06 ?
  #113
Old 08-18-2014, 01:11 PM
g35mok's Avatar
hey i have a 04 6mt and i'm thinking about doing this combo.. i already have a z tube+ pop charger , megan racing test pies, magna flow pipe into hks rears...would it make sense to do this mod even though i don't have the rev-up motor? Or should i just get the spacer with out the mrev2
  #114
Old 08-18-2014, 01:34 PM
Lartytiejdke3's Avatar
wood make know since
Know kneed two by dat
Save your $
Urbanengineer (08-18-2014)
  #115
Old 08-18-2014, 11:42 PM
MaDMaXX's Avatar
Save your $
What the actual F&$%??
To answer your question, g35mok, the biggest gain will be from the spacer, but you will still gain more using the combo, just not as much as a new motor will gain. I have both on the same engine as you.
  #116
Old 09-03-2015, 09:23 PM
Anubis81's Avatar
New to threads but long time reader
Thank u all for this section . I ordered the mrev2 and spacer stillen intake system . Installed everything today plus full time up and relearn . And omg is all I can say def feels like a new toy . Thank u all for all ur insider info
05-22-2022 09:26 AM
Ninjay16
Engine - Intake/Fuel
01-14-2016 01:44 AM
Red G Coupe
Tuner & Dyno
01-14-2016 01:13 AM
w4kj4k
10-02-2015 07:57 PM
Quick Reply: MREV2 + Motordyne 5/16" spacer! What a combo!!!!!!!!!!!
