| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
Motordyne plenum spacer
Received the package today, nice looking spacer Tony!
I first looked over this short guide before doing the install (also linked in GB thread): http://www.hypersprite.com/auto/tech-z-002/index.asp Here are a couple tips I would add so far: There are two studs on the bottom of the plenum that you need to remove. On my coupe they have a torx male end, and I could not find a torx female socket adaptor so I just used the jagged insides of a pair of plyers to unscrew them, it worked but took a while with the limited space available. I would recommend removing the oil cap and covering it with tape to free up more room for removal of the right stud. The plyers grind down the torx a bit, but it's not too bad if you are careful and take your time to match things up. I would also recommend using some washers with the bolts. The stock bolts have the builtin-washer design, but the bolts that come with the kit are just plain hex. In order to protect the upper plenum I would plan on using washers. Tony may include these in the future, but for those that received the plain bolts I would definitely recommend washers. Well I'm off to grab some washers (already had several but not quite enough), will post once I'm finished later tonite... |
I noticed the bolt heads also, fortunately I had some washers around the garage.
An old woodworking trick(maybe mechinics too)---> To make the removal of the 2 lower plenum threaded studs easier, place 2 nuts on the stud & tighten them together, them simply put a wrench on the bottom bolt and unscrew the stud. With the 2 bolts "locked" together the stud will come out easily. Oh ya, those little foam sticky things were not expected. They help hold the 6 spacers inside the plenum to the inner plenum support Other wise no problems or issues. Took it out for a spin afterwards, only time will tell...
__________________
ob09awdg37coupe |
Nice trick with the nuts
Here are a couple pics of the spacer installed... ![]() . . ![]() Fit and finish are exceptional! Now I'm off to start her up... Last edited by copbait; 02-08-2005 at 04:41 AM. |
Well, there is a definite sound improvement
You know that sweet sound the ztube pumps out at around 3krpms? Well I'm hearing it start to kick in earlier, like around 2.2k or so Then once it's past 3k I'm getting a nicer and deeper growl from the exhaust. The ztube sound is now somewhat drown out by the exhaust growl after 3k (which is a good thing =), but the ztube sound does seem higher pitched compared to what it was before. Also, I could almost swear that it's a bit deeper at idle as well, but can't tell for sure.I have not done an ECU reset yet and didn't get a chance to check WOT sound or butt-dyno, will give that a try tomorrow, although I prefer the battery disconnect method so it may be a few days. Right now my only mods are ztube + K&N. I'm hoping the spacer works well with the ypipes and cats which should be arriving any day now
Oh, Tony is now including washers with all packages, so this should no longer be an issue. I think just the first few got shipped without them...
How's the butt dyno so far...noticable improvement?
Question for you.....
Mine is due to be here tomorrow.About the 2 studs in the lower plenum.... Why do you need to remove them??? Can't they just be left as guide posts....or there bolts to replace them???
__________________
996 C4S '03 G35 6MT - Vortech'ed - SOLD |
Quote:
the 2 guide posts each have a nut at the top which also double as a bolt down point. but with the new spacer they are now to short.
__________________
ob09awdg37coupe |
So what's the consensus from the guys that have done the install? More growl is nice but I didn't buy it for that.
Can you fit the cover back on?
Quote:
in the pics can you see the spacer? i want one of them but dont know exactly what it is and what it does(difference in size)---thanks---Court
Quote:
Run a search, plenty of info out there. Group buy thread is in the marketplace. Ending 2/14. |
| Tags |
| dyno, moder, plenum, spacer |
| Thread Tools | |
| Display Modes | Rate This Thread |
