DIY: Rear springmount mod to even out rear
Old Jan 29, 2007 | 02:53 AM
redlude97's Avatar
Since I keep getting PMs about this mod, and I needed to get a couple more MM of clearance in the rear. I decided to purchase a new set up rear springmounts and recut them, taking a little bit less off this time. Credit goes to Gsedan35, who was the first to do this, and Borahatch for giving me tips on how to go about cutting the mounts.
See Gsedan35's DIY on installing springs to remove the rear springmounts.
http://www.g-owners.com/article_read.asp?id=25
The pieces look something like this:
Side
Top
Tools:
Hacksaw
Tape
C-Clamp
Vise
WD-40 or similar lubricating spray
Rags
Start by taping a ring around the springmount of exactly how much you want to cut off. How much you cut will be how much more drop you will get so measure accordingly before cutting. I used Duct tape, but anything will work as long as it sticks to the rubber. I don't recommend blue painter's tape, because I used it the first time and it doesn't really stick to the rubber.
Next, get a rag or in my case some disposable gloves and insert into the hollowed out end of the springmount to provide a cushioned area for the C-clamp to seat to. Install the C-Clamp like in the picture and tighten until the springmount is difficult to rotate/move. Make sure to not overclamp or you can crack the plastic.
Insert the C-Clamp into your vise to provide a stable cutting rig
Get out your hacksaw and WD-40 or equiv
Begin by lubricating your hacksaw blade and springmount by spraying WD-40 onto the blade and rubber, and begin sawing along your tapeline. The outer ring of the springmount is rubber, but the inner ring is made of a plastic, so saw through the plastic. Loosen the clamp and rotate the mount 1 notch and retighten and continue sawing until you cut all the way around the mount, being careful to cut as straight and evenly as you can.
Once you finish cutting, you should end up with something that looks like this, they aren't exactly straight, but close enough, I've been running them for 6 months and no problems here
Here is a comparison of the height difference after cutting, ~1/2"
Reinstall in stock location
End up with a even drop! Dropped on 350z Tein H-Techs, but will work with any spring
Be prepared for camber issues in the rear, just like any drop in the rear over 0.4", I installed the SPC rear camber kit as well and will be getting an alignment soon.
Old Jan 29, 2007 | 02:59 AM
Calvin's Avatar
Overglorified Altima
very nice/informative write up. this will help a lot of people. you should post this in the DIY forum, too. it won't get as "lost" in there since there are less threads in that forum.
Old Jan 29, 2007 | 03:08 AM
redlude97's Avatar
Done
Old Jan 30, 2007 | 12:30 PM
6spG's Avatar
What about using a belt sander instead of a hacksaw to make it even?
Old Jan 30, 2007 | 01:29 PM
denverinfiniti's Avatar
NICE!! This is a awesome idea. I never thought of this. The uneven height between front and rear is my biggest complaint on a customers G coupe that i put tokico d-spec springs and shocks on. The front lowered nicely. But if anything the rear lifted.
Old Jan 30, 2007 | 01:33 PM
redlude97's Avatar
You could try, but my guess is the rubber would melt from the heat, and you'd just end up with a big mess on your hands
Old Feb 1, 2007 | 01:19 AM
GreenGoblin's Avatar
The goblin resurrection
Very good write up
rezendvous420
May 31, 2020 01:26 PM
TreeFiddy
Aug 10, 2015 06:50 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
