DIY: Cutting Rear Springmount aka "the springmount mod"
Rating: Thread Rating: 8 votes, 5.00 average.
Old 01-29-2007, 03:08 AM
redlude97's Avatar
Since I keep getting PMs about this mod, and I needed to get a couple more MM of clearance in the rear. I decided to purchase a new set up rear springmounts and recut them, taking a little bit less off this time. Credit goes to Gsedan35, who was the first to do this, and Borahatch for giving me tips on how to go about cutting the mounts.
See Gsedan35's DIY on installing springs to remove the rear springmounts.
http://www.g-owners.com/article_read.asp?id=25
The pieces look something like this:
Side
Top
Tools:
Hacksaw
Tape
C-Clamp
Vise
WD-40 or similar lubricating spray
Rags
Start by taping a ring around the springmount of exactly how much you want to cut off. How much you cut will be how much more drop you will get so measure accordingly before cutting. I used Duct tape, but anything will work as long as it sticks to the rubber. I don't recommend blue painter's tape, because I used it the first time and it doesn't really stick to the rubber.
Next, get a rag or in my case some disposable gloves and insert into the hollowed out end of the springmount to provide a cushioned area for the C-clamp to seat to. Install the C-Clamp like in the picture and tighten until the springmount is difficult to rotate/move. Make sure to not overclamp or you can crack the plastic.
Insert the C-Clamp into your vise to provide a stable cutting rig
Get out your hacksaw and WD-40 or equiv
Begin by lubricating your hacksaw blade and springmount by spraying WD-40 onto the blade and rubber, and begin sawing along your tapeline. The outer ring of the springmount is rubber, but the inner ring is made of a plastic, so saw through the plastic. Loosen the clamp and rotate the mount 1 notch and retighten and continue sawing until you cut all the way around the mount, being careful to cut as straight and evenly as you can.
Once you finish cutting, you should end up with something that looks like this, they aren't exactly straight, but close enough, I've been running them for 6 months and no problems here
Here is a comparison of the height difference after cutting, ~1/2"
Reinstall in stock location
End up with a even drop! Dropped on 350z Tein H-Techs, but will work with any spring
Be prepared for camber issues in the rear, just like any drop in the rear over 0.4", I installed the SPC rear camber kit as well and will be getting an alignment soon.
The following 2 users liked this post by redlude97:
KnowScott (01-24-2012), nbarkins (11-02-2012)
Old 01-29-2007, 11:01 AM
Calvin's Avatar
Overglorified Altima
now it won't get lost
Old 01-29-2007, 12:52 PM
O HELLA JDM's Avatar
thats a crazy drop... ehh id be too lazy to cut springs...and then i would need a chamber kit....ehh me and my broke ***...but thanks for the DIY
Old 01-29-2007, 01:01 PM
Hi-TechG35's Avatar
Location: Pothole Central and still ridin slammed...Boston
Nice!
Old 01-29-2007, 02:27 PM
Steel Blue's Avatar
You are NOT cutting the springs, but rather the spring mounts.
Old 01-29-2007, 02:48 PM
jiggafree's Avatar
are you going to sell your precut spring mounts????
Old 01-29-2007, 04:38 PM
redlude97's Avatar
Actually, I have my first ones for sale, they are the ones that achieved that drop in the pic. I'll post something in the marketplace when I get some pics up.
Old 01-29-2007, 04:39 PM
redlude97's Avatar
Its a camber kit, and did you read my post at all? I never once mention cutting the springs
Old 01-29-2007, 04:40 PM
Jeff92se's Avatar
Red Card Crew
Gotta love the "two in the pink and one in the stink" hand gesture
Old 01-29-2007, 07:06 PM
Calvin's Avatar
how much do you plan on selling them for? i might get them and sell them as a package deal when i sell my 350z h techs
Old 01-29-2007, 07:12 PM
redlude97's Avatar
I was thinking $50+shipping, basically the cost of a set of new ones, except they come premodified.
Old 02-21-2007, 07:57 PM
GWord256's Avatar
That looks easy enough to do. I'd like to drop the front just a tad for a bit more agressive look. Maybe 1/4 to 1/2 inch.
How long would it take to do the springmount mod (e.g. is this a one day/weekend job)? And could any Joe-Schmo do it? I've got some tools and would buy the rest as needed but I never worked on suspension before.
Old 02-21-2007, 09:28 PM
redlude97's Avatar
doesnt work on the front, this is only for the rear
Old 02-22-2007, 11:11 AM
g35brandon's Avatar
How hard are the springmounts to get out in the first place?
Old 02-22-2007, 01:10 PM
redlude97's Avatar
If you know what you are doing, it takes longer to take the wheels off than to remove the springmounts. I can do it in ~10 mins per side including removing the wheels
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: DIY: Cutting Rear Springmount aka "the springmount mod"
