KSport Kontrol Pro Blowout Special!!!
Old 09-10-2015, 05:27 PM
sales@czp's Avatar
Talking KSport Kontrol Pro Blowout Special!!!
We have overstock on our KSport Kontrol and are looking to clear them out FAST! Now is your chance to take advantage of unbelievable savings and get your Z on the low low for the low low! Shoot me a PM or you can email me here: brandon@myczp.com
KSport Kontrol Pro CNS260-KP for the 03-08 350Z, 03-07 G35 Coupe and the 03-06 G35 Sedan $820 Shipped!!!
$820 Shipped!!!
$820 Shipped!!!
$820 Shipped!!!
$820 Shipped!!!
$820 Shipped!!!
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response.
Pillow ball top mounts in the front and rear on some applications allow the vehicle to install and setup to OEM specifications. Ksport’s patented upper pillow ball mount offers the same level of adjust-ability and performance, but allows for compliance that is often required from high-demand strut applications.
Most applications utilize an adjustable lower mount, which means height adjustability without losing suspension travel—a problem found in many coilover systems available today. Since mounts and most pieces in the coilover system are designed from 6061 billet aluminum, the components are lightweight, durable, and rust resistant. Steel shock bodies are electroplated with zinc to resist rust and protect from the elements. The shock or strut valving for each piece is matched accordingly to the spring rate, giving superior ride quality and reliability.
The Ksport system uses a monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube construction, the monotube design dissipates heat faster and more evenly, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation issues are a lot less common in a monotube design, which results in a more consistent ride quality.
The Ksport Kontrol Pro Coilover system has been designed with professional road racing in mind, offering extremely high value and performance for any application.
Old 09-16-2015, 12:08 PM
sales@czp's Avatar
Bumped!!!
Old 09-25-2015, 05:33 PM
sales@czp's Avatar
Bumped!!!!
Old 10-02-2015, 02:39 PM
sales@czp's Avatar
Bumped!!!!
Old 10-14-2015, 01:44 PM
sales@czp's Avatar
Bumped!!!
Old 10-22-2015, 01:58 PM
sales@czp's Avatar
Bumped!!!!
Old 11-03-2015, 09:37 AM
sales@czp's Avatar
Bumped!!!
Old 11-16-2015, 05:24 PM
sales@czp's Avatar
Bumped!!!
Old 11-25-2015, 10:37 AM
sales@czp's Avatar
Bumped!!!
Old 12-09-2015, 10:38 AM
sales@czp's Avatar
Bumped!!!
Old 12-29-2015, 06:52 PM
sales@czp's Avatar
Bumped!!!
Old 06-13-2016, 11:57 AM
Mike@CZP's Avatar
Bumped!!
Old 07-14-2016, 03:55 PM
Mike@CZP's Avatar
Bumped!!
Old 07-28-2016, 01:49 PM
Mike@CZP's Avatar
Bumped!!
Old 07-29-2016, 05:14 PM
Mike@CZP's Avatar
Bumped!!
Quick Reply: KSport Kontrol Pro Blowout Special!!!
