MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > The G-Spot > Sedan > G35 Sedan '07 + > Tech '07 Sedan
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 08-15-2008, 06:41 PM
ramo's Avatar
Re-Installed Stock intake
Question I just put my stock intake back in, and i was wondering if I need to reset with disconnecting my battery?
__________________
07 G35S 6mt Platinum Graphite/Graphite, Prem, Navi, Tech, 4WAS, 20% Tint, Stillen Exhaust, 20" Work Varianza T1S, Eibach Pro Kit.
Old 08-15-2008, 08:31 PM
terrycs's Avatar
G35DRIVER.COM SPONSOR
Quote:
IMHO .... no. The ECU will re-learn based on new sensor readings when you go back to stock. Just drive it.
__________________
2007 G35S Sedan-5AT with a few mods
Link to Nissan / Infiniti Intelligent Key Covers
Battery included with each cover (limited time offer)!
Old 08-15-2008, 09:09 PM
AesonVirus's Avatar
I'm Infectious
Yeah, my ECU is set on the most aggressive setting it has, I'm sure.
I'd hate to have to reset mine.... all that hard driving wasted!
__________________
07 G35x, Blue Slate on Graphite, Prem/Nav/Tech, Rosewood Trim, FI Cat-Back, 19" MRR GT1's, Paddle Shifters, Nismo Chin Spoiler, GTR Overlays, Illuminated Kick Plates, Huper Optik, 3M & Interior LEDs G35Driver.com license plate frames available for order here
Old 08-15-2008, 09:58 PM
earth0's Avatar
Quote:
+1 no
__________________
08 G35x/PADDLE SHIFT/JDM 8000K D2S D2R HID Bulbs/Add On FogLight/4000K PIAA Xenon Foglight/Tints/White Parking City Light/LED Light Carbin-Door/Headrest TV,Nismo NISMO Chin,BERK HFC's,StockIntake,KP TECH window Roll Up,GTSpec Front Tower Brace18inch XS Rims
JWTPOPchrger&Grounding Wires installed
Old 08-15-2008, 10:00 PM
Did you notice any difference going back to stock ?
__________________
08 G35 liquid platinum, graphite, premium, navigation, 18" tire pkg.
Old 08-15-2008, 10:14 PM
earth0's Avatar
It's hard to said but base on PPL dyno and my feelings on pedal..YES!!
better than Stillen.HFC's and Stock Yes!!!
__________________
Old 08-16-2008, 12:46 AM
lol, true true...i have a question though...if the car is in manumatic mode does it really matter if you have an "aggressive" setting or does this only matter in auto mode and DS mode?
__________________
07 Lakeshore Slate G35S | Debadged I N F I N I T I | 20% Tint | Stillen Wing | JL 12W3V3 250/1V2 | Injen Dual CAI | Kenstyle Spats | Front Lip coming... | CC Super LED Headlight Conversion | FI Header-Back | GVN-52 | JIC Magic
Old 08-16-2008, 12:53 AM
I would say that it's mainly the D gear where the ECU learning really affects it, however maybe the ECU plays with the throttle sensitivity based on your driving now that would be a different story....
__________________
'07 G35S 6MT B on B, Nav/Tec/Prem, 4WAS, Spoiler, 15% Tints, Bel RX65 Stealth, Foot LED illumination, White LED interior, Illuminated Kickplate, Viper 5701, Stillen Roof Spoiler, 20" MRR GT1 Black w/Polished Lip... FI Exhaust & EBC D/S Rotors awaiting install, R2C intake on order...
Old 08-16-2008, 01:17 PM
FWIW, I think everyone is way too obsessed with the ECU learning in this car.
It won't make a difference at full throttle at all.
And if you drive an auto and want to go faster, just give it more gas. If you drive a manual, just shift later.
__________________
2007 G35 S auto. Sunroof, factory spoiler, splash guards, tint, Image Dynamics IDQ10v3 sub.
Old 08-16-2008, 06:27 PM
Check this link from the TechnoSquare RE-Flash thread
http://g35driver.com/forums/3339951-post86.html
The baseline parameters of the ECU will be remapped in a manner that will allow for full open throttle. The baseline setting at full throttle is at around 80% of full open. All the ECU learning and hard drving will never allow the ECU to to go beyond its defined parameters. The primary function of the re-flash is to reset the baseline parameters so the car can perform at the highest level possible given its current configuration.
__________________
08 Black G35 Sports Sedan- 19" Volk Titanium Gun Metal GTF's / Stock Intake, K&N Drop Ins/ FI Exhaust
Old 08-17-2008, 01:44 PM
80% of what exactly? Are you talking about how "open" your throttle bodies are? Because that's a mechanical thing, not a tuning thing.
Honestly, it sounds like tuning BS.
All a reflash is going to do is change things like timing and A/F. You can also change your shift points, and rev limiter, etc.
There's no "full open throttle" setting. When you floor the car, you're at 100% throttle. There's nothing past that.
__________________
Old 08-17-2008, 01:45 PM
The second part about "resetting parameters" is correct though.
And no matter what they do, the bottom line is all that matters.... how much power you get.
__________________
Old 08-17-2008, 03:38 PM
earth0's Avatar
To proof that you should find MODs G35s in your area and run 1/4miles.
Let see if your Stock g can go faster or not. Just want to clearify yurs curious.Anyone in silverG2007 area pls!!!!!
__________________
Old 08-19-2008, 03:51 PM
I may need a translator for this one.
But, are you saying that I should run my car in the 1/4 mile and compare that to someone else who's had the tune done?
Sure, but that won't prove anything.
First of all, different cars run different times stock. One G35 could run a 13.8 while another runs a 14.1.
Then, there's driver error and weather conditions to consider.
Bottom line, a tune should net about 10hp, or .1 second in the 1/4 and 1mph. BUT, that's going to be hard to prove on a track or a dyno for that matter.
__________________
Old 08-19-2008, 03:55 PM
twin001's Avatar
My brain hurts now......I'm still trying to decipher it an hour after I read it the first time.
__________________
2006 6MT Coupe | Nav | RAS | PowerLab | Motordyne MREV & XYZ | Hotchkis | UTR | K&N | OSIRIS | Project Mu | Falken | NISMO
TULSA DYNO DAY, WED NOV 19th...click here for details
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
