MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > The G-Spot > Sedan > G35 Sedan '07 + > Tech '07 Sedan
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 08-20-2008, 02:43 AM
TechnoSquare 2008 Sedan ECU RE-Flash
Here are the results of the ECU flash on my 08 Sedan at TechnoSquare with pictures and charts.
First a few comments. My car was down for two weeks while my ECU was sent to Japan to pull the code. Not sure how this is done, but when it is returned Tadashi has all of the tables that control all engine management functions, transmission shift points, and all sensor limits.
The re-flash does a number of things. The top end governor is removed; the air fuel mixture is adjusted, timing is adjusted. The throttle response and position is adjusted. (This is a throttle by wire car and the throttle is controlled electronically.) Shift points are adjusted to max redline. Tadashi ran 11 pulls on the car over a period of approximately 3 hours. The first few pulls were to establish the baseline and A/F mixture. Once that was done he pulled up the code from my ECU, copied it to another file, and from that file made the changes to the ECU. He over wrote the ECU 11 times until he got the tune to the level where the car responded best. It is interesting to note that at the high end of the RPM in the stock configuration, the system dumps a lot of fuel into the cylinders at around 7600 hundred RPM, you can see a significant drop in power at this point with this rich mixture. The re-flash evened out the A/F mixture at 12.5 through the entire RPM range, up to 8500 RPM no fuel dump or richening at the high end of the RPM range. The max A/F with the tune is 13.9 versus 14.9 in the stock mode. The car pulls hard on the dyno and it is almost scary to see your tach go to 8500 RPM!
For those of you worried about a dealer knowing you flashed the ECU, I asked Tadashi about this so I could respond on the forum. The dealer will never know as the dealer cannot read the ECU, all the dealer sees is the output of the sensors, and they will all appear normal with the new mapping as it does not register any faults. In addition Tadashi assured me the ECU cannot go back to the stock map from learning. All of the parameters of the ECU are changed, so the learning that takes place is as it applies to the new settings, not the old stock settings. As far as the ECU is concerned the new program is its stock settings. No issues with smog as the OBD II connector will read as expected.
Final Tune showed WHP of 283.6, and Max Torque of 232.7 over a very wide margin of the RPM range. Horsepower starts to climb at about 4700 RPM and is at 10 WHP more at 5200 RPM which is maintained through 7000 RPM. Torque comes up fast at around 3400 RPM, pulls strong through 5700 RPM and does not drop off until around 7000 RPM. You can definitely feel it; the car pulls much stronger and does not stop. It is much faster and the feel is very noticeable in throttle response and just overall power, it really pulls, the feel is unmistakable. I believe the torque is what makes the difference in this tune, HP gains are what I expected, but Torque is significant in numbers and feel. Max Torque in stock mode is 220, tuned is 232.7, I would round that up to 233. In sport mode it is even more pronounced, and yes you can take it up to 8000 RPM for your shifts! If you get this tune you will not be disappointed.
I’m sorry to say that those of us with Stillen Intakes are loosing power and torque. In the tuned mode it drops back to stock numbers, along with the torque. I’m back to stock air boxes.
http://i539.photobucket.com/albums/f...g?t=1219210342
http://i539.photobucket.com/albums/f...g?t=1219210526
http://i539.photobucket.com/albums/f...g?t=1219210585
http://i539.photobucket.com/albums/f...g?t=1219210697
http://i539.photobucket.com/albums/f...g?t=1219210769
__________________
08 Black G35 Sports Sedan- 19" Volk Titanium Gun Metal GTF's / Stock Intake, K&N Drop Ins/ FI Exhaust
Old 08-20-2008, 02:57 AM
How can i get this on my car? is what i need to know
Old 08-20-2008, 02:59 AM
WOW! Nice Numbers!! Man I wish I lived in Cali! Would love to go to his shop and get a tune!! But man, I wonder if the Injen CAI I have put on, or JWT Pop Chrgers lose HP also?? Think I will call Techno and see if they have my ECU already Decoded and ready for a flash? How much does the Flash itslef cost, without Dyno? Since Obviously I cant get a dyno from him, unless his whole shop floats on Water to my Place! LOL. Thank's again for showing and informing us of your Results!
__________________
07 G35S Blue Slate\Graphite - 6Spd - Premium - Trunk Spoiler - 5% Tint - Debaged - Eibach Springs\Camber Kit - JDM Tails - 8000K Bulbs - INJEN Dual CAI - G37S 19's - STILLEN Sways -STILLEN Cat-Back Exhaust - GT Spec STB
Old 08-20-2008, 03:45 AM
TechnoSquare has the code for your car. You may need the part number from your ECU, check with TechnoSquare. I don't know what the flash is wihtout the Dyno, you'll have to call them. No aftermarket intakes they have tested produce any power. I specifically asked about the Injen CAI. Sorry to say the reply from Tadashi is that they are the worst. He showed me numbers from some tests he did last week, worse than the Stillen.
__________________
Old 08-20-2008, 04:06 AM
very nice...interested in doing this. how much did it run you about?
__________________
2008 Infiniti G35 Sedan Sports: Blue Slate with Graphite Interior, Premium, and Rear Spoiler
Old 08-20-2008, 05:05 AM
Quote:
+1 as well. I'd be interested to find out more details!
__________________
2007 G35 Sport 5AT * Black Obsidian * Graphite Leather / Aluminum Interior * Premium pkg * Navigation pkg * OEM Spoiler * Tint
Old 08-20-2008, 07:35 AM
AesonVirus's Avatar
I'm Infectious
From the other threads I have read, I believe this is $450-
__________________
07 G35x, Blue Slate on Graphite, Prem/Nav/Tech, Rosewood Trim, FI Cat-Back, 19" MRR GT1's, Paddle Shifters, Nismo Chin Spoiler, GTR Overlays, Illuminated Kick Plates, Huper Optik, 3M & Interior LEDs G35Driver.com license plate frames available for order here
Old 08-20-2008, 07:43 AM
I'd be so willing to do this, although I just don't think it would be very possible to do so since I live in Dubai.
I may look into shipping out the ECU in the near future and having it done though.
__________________
2007 IP G35 Sedan
Old 08-20-2008, 08:11 AM
G35Robby's Avatar
Armenian Driver
wow injens r worse than stillens after re-flash???
wow i just wasted 550 bux
Old 08-20-2008, 08:14 AM
Hopefully the popcharger will prove to be better
__________________
2007 IP G35 Sedan
Old 08-20-2008, 12:35 PM
i guess we all have to face the fact that the stock intake system is best. I wish we could at least get a company to make a carbon fiber box lol
__________________
07G35SportPremium-3kFog,6kHeads,LEDs,Sevas20's staggered,PaintedHeads/tails/grill, BluebatRoof&rear,H&Rsprings,hyperground system,voltstabilizer,FIexhaust,InjenCAI,and PS2(14.0@101stock)
Old 08-20-2008, 12:36 PM
i remember when i had my ECU chipped for my honda we had to do it on a dyno but thats probably because of the multiple different mods and parts for a honda? but with the G has anyone done the ecu reflash without going onto the dyno? meaning they use a base reflash program for everyone who sends it in?
im wondering how much a seperate ecu would be if someone was to want to keep their original stock.
__________________
Old 08-20-2008, 02:39 PM
"The max A/F with the tune is 13.9 versus 14.9 in the stock mode. "
Explain this for me please. At what point is this?
The lower the number, the more "rich" the car is running. Stock, at part throttle, you should be around 14.7 to 1. At full throttle, 12.5:1 is a safe tune. You can go slightly leaner than that at full throttle and gain power, but you'll risk detonation.
If you change stoich (14.7:1) at part throttle, you'll kill your fuel economy.
Also, did they do any part throttle tuning? Adding timing there is where you can get the best SOTP results from a tune.
__________________
2007 G35 S auto. Sunroof, factory spoiler, splash guards, tint, Image Dynamics IDQ10v3 sub.
Old 08-20-2008, 03:06 PM
terrycs's Avatar
G35DRIVER.COM SPONSOR
If the 283 WHp was on a 5AT ... that is a MAJOR increase from the TS reflash.
Let me put this into perspective, my car with the same FI exhaust and stock intakes did 252 WHp and 259 WHp, each on two different dynos.
That easily makes the TS reflash the biggest bang for the buck when it comes to bolt-ons.
__________________
2007 G35S Sedan-5AT with a few mods
Link to Nissan / Infiniti Intelligent Key Covers
Battery included with each cover (limited time offer)!
Old 08-20-2008, 03:18 PM
20-30hp gain...
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
