MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > TSB- Technical Bulletins
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 08-05-2006, 06:57 AM
Wierd smell from engine! HELP!!
today i was driving my 04 g35 6mt and i started to smell an electrical smell that seemed to be coming from the engine..has this happened to any1? after a while the smell went away, but i would like to find out wat the problem is..so if anyone knows wat could be causing that smell it would be great to know.
thanks
-ishida23
Old 08-05-2006, 07:10 AM
I'm getting the same smell,could be oil or some other fluid.Happens usually when I'm entering the highway and gun it.Only lasts a few seconds but would like to get to the source of it.
Old 08-05-2006, 07:12 AM
Quote:
'04-G35-5spd auto.
Old 08-05-2006, 07:13 AM
yea..thats exactly wats happening. it starts when im gunning it. but my smell stays for a while...so i just hope its nothing serious
Old 08-05-2006, 07:09 PM
can't really tell if it's really serious or not...but you'd always smell the gas smell everytime you gun your car....always experience it everytime i gun mine (for 2 years)...have no prob so far so i assume it's NOT serious
Old 08-08-2006, 04:47 AM
after I do a hard run, I can smell something like a burn oil smell, but it goes away after a few seconds.
Old 08-28-2006, 11:48 AM
Mine does it too. I sure would feel better to know what it is. Like everyone else, I only notice it when I've run it hard. Mine's an automatic and when I do run it hard, I do it in "manual mode". I can't believe no one has figured out what's causing it yet.
Old 04-29-2008, 04:26 AM
same thing here,, cant figure it out where its coming from.
__________________
03 Sedan, fan delete, freeflowing muffler, 5/16 spacer, SAFC2 tuned, throttle body spacer, intake tube 10% larger than Ztube
Old 04-29-2008, 10:24 AM
aRT13's Avatar
Just PIITB...
I'm 04 5AT I had the same problem, but mine's a tad off the electrical smell topic.
Mine smelled like a cinnamon roll. I popped the hood, could not find anything..... So, I took it back to the dealer, turns out when I had the car serviced, the tech dropped a piece of his danish which lodged in my engine bay and began to melt and drip.... lol
No, but I do experience that electrical smell too. In fact, I just had that the other day and I swear I thought my car was on fire. I was about to pull over. When I got home, nothing...no smell whatsoever anymore.... lol
__________________
04 G35c-DG | AEM CAI | OBX-TBS | SxExCx 12-Wire Active Ground Kit w/Voltage Stabilizer | Polished Plenum | JDM Clear Corners | 07 Projectors | 05 Brake Upgrade | V-LEDs | UR Pulleys | NGK Iridiums | ELF Oil | 350z VQ Cover | 20% Tint | FALKEN 452's 245 & 275/40/18 | TSW Catalunyas
Old 04-29-2008, 01:49 PM
I started smelling that also. ....
What scars me is recently I changed to full synthetic M1 5W30 and hope it is not that ..
After i stop after a long ride, there is a "oil burning" smell and it goes away after some time.
__________________
2003 G35 Sedan, Black Obsidian/Willow, 20 tint all around, K&N cold air intake
Old 04-29-2008, 02:46 PM
yes i would add that the smell has a hint of an electrical wires burning type of odor. There was a few times I was thinking of pulling over, I thought i would catch fire .. It is really hard to pin-point this issue it comes and goes, I just hope my car doesn't just catch fire one day.
__________________
Old 04-30-2008, 11:46 AM
SwivelHips's Avatar
Where's the Kaboom?
I get this occasionally too, and don't have to run it hard, just at the end of my normal commute. No evidence of leaks or anything. I run synth oil and my car is 5AT.
__________________
2003.0 Emerald Mist Premium Sport 'Doggy Door' Sedan
I have the right to remain silent, just not the ability
Need Amsoil/Wix products? PM me
Old 06-18-2008, 11:42 AM
i have had a 04 g35 sedan 5AT and now a 04 Coupe 6MT and they both do that.. the smell is a raw gas smell even though it doesnt seem like it . the prob is usually caused by not burning premium gas like your supposed to. but if you do run premium and u still get the smell i would change my spark plugs.
Old 08-03-2008, 11:59 AM
that happens when you do not push your oil dip stick in all the way, as the motor runs, especially when you gun it, oil starts comeing out.
Check your dipstick and check that whole area down below for any oil residue
Old 08-03-2008, 02:10 PM
bythabay's Avatar
I'd also check the spark plug tube seals for leakage.
__________________
Maintenance, modification, and repair services. Email me for info. info@infiniticare.com DIY Video Series: http://g35driver.com/forums/g35-seda...eo-series.html
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
