MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > TSB- Technical Bulletins
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 09-20-2006, 11:44 PM
Otacon132's Avatar
Hutman
Problem with the car starting - battery die?
for the 3rd time in less than 2 weeks, my car doesnt want to start. Its almost as is the battery is dead, when i turn the key i dont hear click click click, like normally do when the battery is dead, but just no response at all. At first it seems fine, but the moment you go to crank you see all the lights dim as if it doesnt have power to start. Then when you go to turn the key again, nothing...dead, no battery power at all.
The first time it happened i rolled it out the garage and poped the cluitch in reverse, it started. Second time i was parked on the side of the house so i was able to push start it alot faster this time, it didnt start....but it kinda bogged to a stop in first, but the battery had gained enough power (somehow) to start the car normally. This third time was just now and on my oval drive way, went to garage the car for the night and same scenerio as before.... unlock...get in....key in ignition (lights turn on) crank it.....all lights dim (battery is drained)....and this time, not room to push start.
I ended up sitting there like 2 min thinking wtf to do, before all of a sudden the power was back, and all the dash and radio lit up (key was in ignition). I imidiatly started the car just in case.....
So my car is parked in the garage and im gonna take it in for service tomoro after classes. But what could this be? i dont think its the battery since that last time it happened, since the power came back suddenly, but a false contact somwhere in the car? Im scared they will blame this on my system....eventhough its not even connected atm, since the power cable fell out and i havent had time to reconnect it (its wrapped up and im sure its not touching anyhting).
Suggestions?
__________________
2005 Lakeshore Slate 6mt Coupe || Greddy Front/Sides ~ Kenstyle Rear ~ Seva S-55 20" ~ HKS Ti Exhaust ~ Stillen CAI/Z-Tube ~ 06 Projectors ~ BBM Tailight Overlay's ~ Sirius Radio ~ KP Tech Roll-Up Mod ~ TVandNav2Go conversion: PS2/Backup Cam ~ Alpine Type R 10" x2 || www.cardomain.com/ride/2102069
Old 09-21-2006, 09:09 AM
either your battery cables are loose or the battery has an internal short.
__________________
FUNCTIONTUNED:POWER
Old 09-29-2006, 03:22 PM
im having the same problem, got battery replaced and still does it. I'm pretty sure its a kill-switch issue with the clutch. Im goin in for service at infinity on next wednesday, ill let you know wth happened. oh, and it seems if you disengage the clutch, and the ebrake, then re-engage the clutch and ebrake, it starts... hmmmmmmmmmmmmmmmmmmm
Old 10-02-2006, 05:24 PM
update: car won't start AT ALL, anyone else have this problem?
Old 10-17-2006, 01:24 AM
update on this?? im having a similar problem
__________________
Quote:
Originally Posted by Bigd2k6
"You realize you were doing 90 in a school zone?" "Oh, yeah. Sorry about that.... I debadged my speedometer numbers. They're so freakin' annoying."
Old 10-27-2006, 10:55 AM
update:
My clutch sensor was toast, so my car didnt think I had the clutch in. It was fixed by the dealer, havent had a problem since!
Old 12-27-2006, 03:08 PM
its happening to me also and i have an 03 automatic... im going in on the 2nd of jan, but i'm scared they tell me its the computer.... any suggestions on what it might be
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
