MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > TSB- Technical Bulletins
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 01-21-2007, 07:35 PM
Need Help, car will not start now
My car was running fine until yesterday. It was very snowing here; it took me 30 minutes to get my car back in the garage. I was driving/working it pretty hard. Once I got it in the garage, I noticed the brake and battery light were both on. I simply tried restarting it, the brake and battery light were still on. I decided to let it sit over night, same results. I then took it for a spin around the block, the anti lock brakes worked, all dash lights worked, but still no power steering. On top of that the car would almost go to idle when the heater was on for around 2 minutes or more. Finally I got the car back home, but now it will not even start. Any suggestions???????????? Thank you for any help.
Regards,
Old 01-21-2007, 07:41 PM
jjyellow's Avatar
Sounds like possibly broken belt
Old 01-21-2007, 09:09 PM
I just went and tried to start it again, it started, but the brake and batter light is still on. Will a broken belt mess with electrical part of the car?
Old 01-21-2007, 11:44 PM
jjyellow's Avatar
It will affect the electrical system b/c it affects the alternator. Just pop the hood and give a peek
Old 01-22-2007, 12:04 AM
Thanks for all of your advice.
Regards,
Old 02-22-2007, 06:43 PM
where would I see this belt (noob = me) because I just had this EXACT same problem. ebrake exclamation and battery light are on, can wouldn't start at first and eventually started...
Old 02-23-2007, 01:05 PM
update: My problem was the daytime running light modulator; they replaced it. at the same time they ordered a new part because there's a TSB for a no-start issue that the sedan has.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
