MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > TSB- Technical Bulletins
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 03-09-2007, 02:40 PM
fzr fzr is offline
Noise in back when speeding up
This does not happen all the time but sometimes when I speed up only when I press on the accelerator I hear this metal on metal sound coming from the back, as soon as I let go of the accelerator the sound is gone, when I accelerate again its back, I dunno could it be pad rubbing against rotor???
Thanks
__________________
2004 G35 Sedan Black/Black
Old 03-09-2007, 04:58 PM
Do u have an after market exhaust on and if u do check and make sure that nothing loose under the car because i did have that problem when u accelerate ur exhaust vibrate alittle bit so hope that help u out
Old 03-12-2007, 03:18 PM
fzr fzr is offline
car is 100% stock
__________________
Old 05-08-2007, 12:31 PM
I have the same problem, sort of like a humming sound, only when I press on the gas, right rear, can't be the wheel bearing otherwise I'd hear all the time.
__________________
03.5 G35 Sedan-5at. Brilliant silver/premium package/motordyne 5/16" spacer/z-tube/drop in k&n/10 wire grounding kit/'05 midpipe/350evo rear swaybar.
Old 05-16-2007, 01:20 AM
i also have the same problem on a 03 sedan
Old 05-16-2007, 02:09 AM
ttrank's Avatar
TIMMAHH!!
May be an exhaust leak. I know it sounds strange but I have had one before on my last car and it sounds different once it comes through the cabin.
__________________
ONE FUN SEDAN!! MY CAR (LINK)
Greddy Twin Turbo + Built Motor by UMS Tuning = 649whp/651wtq Rotora (12pot) 20" IForged Quad Projector Retro Custom Dual 3" Twin Muffler Exhaust by Nichols AutoFab
Old 05-14-2008, 01:45 PM
Same Problem!
I just picked up an 07 coupe last week, and am having the exact noise. A friend and I spent about an hour and a half trying to figure it out. After a lot of trial and error we think its coming from where the suspension attaches to the car. When your in the car is sounds like a speaker is loose but we dropped the seat and I rode around with my head in the trunk and its definitely not speakers, its something in the right side of the car. I hope its the suspension at this point and the easy fix is to tighten it. The cars is going in to the dealer for it on May 17th. I will repost when the problem is finally fixed.
B
Old 05-15-2008, 10:32 AM
surfquikslver's Avatar
Your license plate is probably loose and rattling when accelerating
__________________
FOR SALE- Ivory pearl painted MG trunk / Ivory pearl painted 350z engine cover
Old 05-22-2008, 08:07 PM
Just got the car back from the Infiniti dealer. Rattle is not fixed, they have to order a part. There are two different things that is can be and the most common is a part behind the rear seats that connects to the side pillar. The bolts that connect the two pieces come short from the factory and tend to come loose. Creating a metal on metal rattle. I will take the car back in next week for hopefully a final fix. I will post the results.
B
Old 05-24-2008, 06:12 AM
could be your rear end bearings, is it kind of a howling or growling type noise?
Old 05-25-2008, 12:43 PM
The noise is a metal on metal clanking noise. Happens about every 3 to 5 seconds. Sometimes a little bit longer depending the road surface. I really think its coming from the rear right suspension. The sound come through right near the rear seatbelt/ rear seat area. A friend and I put the seat down and he laid back there while I drove around, we really think thats what it is. The car is going back in on June 4th. Hopefully for a final time. I will update as soon as its finished.
B
Old 05-27-2008, 10:30 PM
i got the same problem but from my left rear...i hear like a stretchin noise it happns when i step on the gas if some 1 knows abt this problem help us out
Old 05-30-2008, 01:58 AM
I have a metal on metal popping noise happening in my car to. Mine only occurs when i take a right hand turn into and entrance to a driveway or something. I think it may be suspension related, but i cant seem to figure it out. I have replaced the rear camber arms, the springs, and tightened everything down, and still no luck.
I need an answer as well. any more ideas?
__________________
Old 05-30-2008, 03:18 PM
Seems Like this is an all too common problem. My car is going in Wednesday of next week. Hopefully I will have some answers, my car is under warranty so ill keep it there until its fixed.
Breck
Old 05-30-2008, 05:27 PM
maybe check your sway bar links? also do any of you have aftermarket suspension? did you use all the stock isolators?
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
