Thread Tools | Search this Thread | Rate Thread | Display Modes |
brake/vdc/slip light is on
wtf lol my brake/vdc/slip light is on.......
I turn the car off and turn it back on and it goes away... any ideas i tried to search :0
__________________
2006 G35 IP Sedan 5AT - Stillen Z-Tube , Stillen CAI , Stillen Grounding Wire , M3 Spoiler, Dropped on 06 full 350z suspension , Philips Ultinon D2R 6000k - | PIAA | Luminics | Escort | SFL G35Driver Member FTW |
if it comes on when u just start it up or if it randomly comes up its usually the brake pads are too low
__________________
2003.5 g35 sedan: desert platinum|black roof|limo tint|valentine one|18'' tsw's|coupe suspension|double din|m25 extreme blinder|hotchkiss sways|richie strut bar|dynotune nitrous|coupe midpipe|injen intake |
Quote:
Unless my gremlins were at work like my vdc/slip light coming on....I think your break pads are worn out...I replaced mine and the problem went away...now I have a semi related problem where my spedo drops, and vdc/slip come on...only with heavy rain...guessing maf/map sensor or something getting wet??? Just throwing that in case it happens to you.
__________________
03.5 G35C B.S. 6MT /Z-Tube w/ K&N/Niche F-18 19x10R & 19x8.5F /Nitto 555/ MOOG Grounding Kit /Aluminum Pdls/Clear Corners & Clearance wPIAAS/ARC Strut Bar/JIC Y/Fuji Exhaust/GT Spec Ties/ |
I just had mine come on today while driving & when I sut it off they were not there on start up & then they came back. It started with all 3 lights on VDC, SLip, & Brake warning, then after my next start up just the slip & VDC light. I guess I will check the pads but my 05X only has 27000km (16,000 miles) on it.
Can the pads be gone already? That sucks if it is. ![]()
__________________
Was 03 Red Premium Areo, & then 05 X B on B, now 07 X IP Every option!
Quote:
06-03-2007, 01:51 PM frshgcoupe frshgcoupe is online now Registered User Join Date: Oct 2006 Location: long island Posts: 425 iTrader: (0) Send a message via AIM to frshgcoupe same exact thing happened to me, yupp its your brake fluids __________________ TSZ33 Reply With Quote
__________________
[ FYI - Same issue covered earlier in this forum, thread titled "VDC and Slip Light" started 7/24/2007 by Importroller.]
Just encountered this problem, once the lights all lit up they wouldn't go off unless/until I stopped and re-started the car, then they stayed off when driven gently, but hard driving caused them to light up the board again! Brake fluid was low, topped it off and no more problems. Obviously, if the brake fluid is low, then the pads are worn (unless there is a fluid leak, which would be immediately evident and end in probable sheetmetal damage to the G), so I'll be replacing them soon, I guess. NOTE: Haven't seen anybody mention this yet, but I noticed that when all the lights lit up (VDC/SLIP/BRAKE), the VDC system was also disabled, at least in my '04 6MT. The tires could be spun at will, and you can also spin the car out quickly and easily (man, the "G" does love to rotate at the slightest provocation when the VDC is off - great for drifting if you are experienced and prepared for it, scary, embarrasing, and potentially fatal if you're not). This can be a real problem if you drive the car hard and expect the VDC "nanny" to keep you out of trouble. In line with this, a review of Importroller's earlier thread reveals that the first time this happened to him (VDC/SLIP/BRAKE lights come on), he spun his car out immediately. Just wanted to warn the unsuspecting. DB |
happen to me about a year ago few times couldnt do anything untill i show them the check engine light...lights came on and the car would barely move...untill i restart it.... i think it was some kinda sensor they replace
__________________
2005 6MT IP Coupe - VsR - Z Tube . K&N . Tien Basics . Project Kics . Volks Sf Challenge . Navi Conversion . 06 headlights . 06 sport bumper . |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
