MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > TSB- Technical Bulletins
Thread Tools Search this Thread Rate Thread Display Modes
Old 04-04-2006, 09:55 PM
New transmission replaced by Infiniti, but maybe new problem?
My 2003 coupe 6MTransmission started grinding third gear at 36k miles. It also had the rattling/rotating noise when the clutch was not pressed down. I brought it to Infiniti at 39k and they ended up replacing the whole transmission. The rotating noise is gone but the car now bogs when going into first and second gear. I have no idea what the problem is. Maybe the clutch needs to be broken in? I dont know. Would you guys happen to know?
Old 04-11-2006, 02:35 PM
what do you mean by bogs...give a better description
Old 04-11-2006, 08:25 PM
Me too
I have a 2003 6MT that is in the shop now. I have ~20k on mine and it was also grinding in 3rd. I just got a call (30 minutes ago) that said they will have to rebuild or replace the transmission. can you tell me if they replaced with a new or a rebuilt transmission. Also what revision of transmission did they use. Finally (man i have alot of questions), did they replace the clutch as well or just the transmission?
Scott
Old 04-12-2006, 10:39 PM
you guys should check your clutch to see if it is loose. i had the same problem i took it to the dealership and they told me i had to replace new clutch flywheel etc..costing about 2k..but after i tightened up my clutch (bolts inside the car) the car drives ALOT better now..
Old 04-17-2006, 02:29 PM
Just to close out this post (and hopefully make the info available for others). The dealership did replace my tranny and clutch. They said they would use the following parts:
Transmission 32010 c/d 008
Clutch Disk 30100 c/d 019
Gear Oil (did not write down the part number)
When i pick up my car this afternoon - i can confirm on the invoice. I was surprised that the problem was diagnosed, parts arrived and installed in under a week. I expected it to be much worse for something like a tranny
Old 06-29-2006, 06:52 PM
I think I have the same problem. SOMEONE HELP!
Reposting in other forum.
Last edited by BB_Sam; 06-30-2006 at 09:51 AM. Reason: Sorry.. this is in the wrong forum.
Old 07-02-2006, 06:02 AM
Hey Mr G3FIZZO, I HAVE A QUESTION, PLEASE HELP!
Did The Grinding Happen All The Time In Third Gear?where U Unable To Get To Third Without It Grinding? I Get Grinding In Third Gear But Only When I Make Quick Shifts From Second To Third Usually Under 2k Rpm. For The Most Part I Can Avoid The Grinding. Should I Be Worried That It Happens At All? By The Way I Am Depressing The Clutch All The Way, Thats Not The Problem.
Thanx.
Old 11-20-2006, 07:37 PM
i get grinding too. i should have it checked out.
Old 11-23-2006, 01:47 PM
My car was not grinding everytime i shifted into 3rd, but as G35ANSTA mentioned, as i shifted quickly into 3rd. I am not sure how important the RPM's are but i could reproduce the grind at 3k. I have not had a problem since they changed out the tranny/clutch. As soon as i could reproduce the problem with a tech in the car, they were willing to change the parts.
Scott
Old 09-30-2007, 08:39 PM
G SQUAD
Fortunately, I have a DECENT Infiniti dealership, so I have had two tranny replacements with no issue from them. My car's synchros seemed to have gone, since it'd grind into 5th gear each time. The tranny's were both the same 2005 revision and yes, you get a new clutch each time they replace the tranny.
This is the first and LAST Infiniti that I buy. I now have a new engine sound from 1500-2500rpm that sounds like a metallic chirping/grinding that goes away after the car warms up. I hope Toyota comes out with a viable sports car soon as I'm done with the Nissan family.
__________________
..................................................G SQUAD VP AND MEMBER FOR LIFE!.................................................. ...................... 2003 Diamond Graphite - 6MT - Brembos, 19" Racing Hart C4's, OEM chin spoiler, Z Tube + JWT Pop charger.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
