MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > TSB- Technical Bulletins
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 12-27-2007, 05:35 PM
Whistle or whine noise when engaging clutch then accelerating.
I've been having this weird noise when I engage in 1st gear. It sounds like my car has a supercharger or something. It only happens when I press the gas pedal. I'm seriously over this 04 6MT. I'm going to test drive a G35s Sedan 6MT today. If I don't feel the love from that car. i'm getting a Evo or a E46 M3.
Has anyone else had this whine issue? I'm thinking it's the belts as i'm approcahing 50k.
Old 12-27-2007, 05:47 PM
elayman's Avatar
Going, Going, Gone**
you should slap on a supercharged sticker and be done with it
__________________
05 BS Coupe - Silver Sevas S-22 | Tein G35 S-Techs | Invidia G200 Exhaust | Stillen Sways | 35% Front & 20% Rear Tint | 06 Projectors | AEM Intake | JL 10W3v2
Old 12-27-2007, 09:27 PM
Does it happen all the time, or only when cold? Mine makes a hissing sound on some cold days, but only for the first couple minutes....
__________________
2004 6mt Sedan with 2 optional baby seats and an "I hate your car!!" doll in the front seat...
Old 01-02-2008, 05:09 AM
mine had a hollowing noise driving when the car is warming up. crusing at 35mph. dealer said transmission is bad and got a new transmission
__________________
tb g35 cpe 06 headlight mod..... http://www.g35driver.com/forums/showthread.php?t=103689 BLUE LED conversion: http://g35driver.com/forums/lighting/39381-stage-4-done-blue-ac-compass-temp-display.html.................................................. ..."NO [U R L], NO [I M G], only 1 line" ........................
Old 01-08-2008, 07:15 PM
^^^ The dealer thought it was your tranny? Hmm... Maybe I'll take it into the dealer and get some wild estimate. It happens when I press the gas pedal slightly or when the clutch is engaging. I can be in first from a slow roll and play with the limbo area with the gas pedal before I start to accelerate and i'll hear that whine noise. The G35 has a rough idle and harsh deceleration when engine braking when down shifting and rev matching.
Old 09-29-2008, 06:51 PM
Any updates? Got the same problem. Does it the whole time driving, not just when the cars hot or cold. Whenever I shift gears then accelerate, it makes the whining noise then when I push in the clutch peddle, sounds like it lets off a little whistle noise.
__________________
04 OB Coupe 6MT * Karuma Z * Impul * Seibon TS * HKS * Tein * JL Audio *
Old 09-30-2008, 11:16 AM
03dgcoupe's Avatar
~matt~
you guys are sure its not the airbox....i have heard that most cars sound like they whistle when they take off
__________________
03' 6MT coupe...in need of some "GO"
Old 11-25-2008, 07:42 PM
My acura integra makes that nose after I installed a cold air intake. Just after you start to apply a little bit more gas, there will be a whirring/whistling sound, if you keep your foot at that spot, the sound is continuous, but if you apply more gas it's gone. I've found a couple of other cars that exhibit a similar phenomeon with certain intake systems.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
