Thread Tools | Search this Thread | Rate Thread | Display Modes |
I've had my 03 in a 3 times to try to Diag the pull to the right. Even took it to an independant who specializes in high end hard to align vehicles.
First; I'm told only one of 3 geometries in the fron end is adjustable. Other two are factory set, so alignment perse, is not adjustable. The front end was just within normal tolerances the 1st measure, and seems to be migrating worse over time. Under close scrupulous investigation, there's no sign of previous impact damage or repairs. my cars got 45k miles. The best recommendation was to check tires, or for brake drag. I had new tires / wheels, and a brake job done. No better. I took it to the dealer for a 2nd look, no luck. Now a month and a half after the 1st alignment, I took it back to the first guy to look at again and the front end tolerances have migrated slightly worse. ???Any body out there had similar alignment difficulties, found any HTF soltions? Thx, David |
The normal reason for changing is from wear and changes in the rubber isolation bushings. In order to maintain as new you will need to replace bushings and arms with bushings...............wear and tear items like brakes and clutches.
Shocks are probably less than half their brand new oem rebound stiffness and usually are done by 60k or 4 years from wear amd tear. [Intenal nitrogen pressure leakage and seal wear]. Of course there is also metal shock tower bending from impact stress and heavier than oem wheels and tires that steady increase negative camber. If you want perfection constant rebuilding will be required, since weight vs durability was the goal to minimize purchase price.
__________________
http://www.t3auto.com/ |
Quote:
__________________
04' 6mt desert platinum w/BREMBO package stillen hfab/utr c/f z-tube/350z c/f eng. cover/s/s clutch line/ jdm rhd battery cover/utr c/f batt covers/stop tech slotted rotors/endless pads/MD 1/2 iso- spacer..to be continued.. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
