MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > TSB- Technical Bulletins
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 04-07-2008, 07:25 PM
Angry Door lock problems.
Hi everyone, i own a 2004 G35 coupe 6MT and im having a problem with my driver door lock. I was leaving work and as i was walking towards my car i pressed my unlock button on my remote. the door was lock still, after a few atempts it still didnt open. however, i did open the door with my key but i knew something was not right. i pressed the swith to lock/unlock my doors and only passenger door would unlock/lock only, my driver side did not move at all. if i leave my driver side unlock, it will not lock, same goes as lock to unlock. from the inside i can only use my hand to unlock or to lock the door. has anyone had this problem besides me? any info is greatly appreciated
Kevin
Old 04-07-2008, 09:30 PM
The problem has been covered many times. It is your door lock actuator which is essentially the motor that locks and unlocks your doors. It is a common thing that goes out on our cars, I just had to replace both of mine on the driver and passenger sides. There is a DIY thread on here which presents a solution for $5 but requires you to remove your door panels and windows. I am not technically inclined so I had a shop do mine.
Old 04-07-2008, 09:42 PM
O HELLA OEM's Avatar
G37S or 370Z?
lol my drivers side door wont lock or unlock so i use my key to unlock my car..so embarrasing..the dealer quoted me like $150 for the motor and labor=$250!!
__________________
o4 DG G35 Coupe|Axis Reverbs|Fujita|NRG..
Im now SAVING up for a 2008 Infiniti G37S or a 2009 Nissan 370Z!!!
Old 04-07-2008, 10:50 PM
Quote:
link of DIY thanks
Old 04-08-2008, 01:53 AM
umm i had that problem ones my door lock wouldnt lock or open!
soo what i did was open the door panel and found that the metal wire that runs to the door lock came out soo i put it back in and i was all set!!!
Old 04-08-2008, 08:09 AM
Quote:
Kevin
I have that problem (driver & passenger side) ONLY when it's too HOT out side (75 & up), so the inside is like 85 & up.
__________________
2004 Nissan Skyline 350GT 5AT, Twilight Blue, Willow Interior l Everything Nissan Skyline (seats coming soon) l DONZ Montana (Black & Twilight Blue)20 X 8.5 F/+20 offset, 20 X 10 R/+30 offset l Nitto NT 555 Extreme ZR, 245/35ZR-20 / 275/30ZR-20 l Tein S. Tech l Impul Rear Wing l MOMO Shift Knob
Old 04-27-2008, 11:26 PM
this problem just came up on mine today... anyone know how to fix it?!
Old 04-28-2008, 12:20 AM
07SilverG's Avatar
i shift at 9 grand
mr car does this on both sides as well...only when its hot out.
__________________
03 LR G35 Coupe with many mod's(SOLD!!)|04 IP G35 Coupe with a few mod's|07 LP G35 Sedan with a few mod's|05 S2K FR stock and staying that way! |SFLG35
Old 04-28-2008, 03:15 PM
Kevin
yeah i just had that problem occur not to long ago...i tried to fix it but it still didnt work...the door system was bad on the passenger side...so i went to buy a new one for almost $150...gl if you need help pm me
Old 05-01-2008, 07:23 AM
i had the same problem. but i have a viper alarm. car wouldnt unlock/lock. took it to a alarm shop to have it looked at. they said it was the wiring,that it was pulled out somewhat, and didnt have a good connection. they said it can happen when u open your door to wide, with too much force. AND/OR that the wiring was ran crappy.
__________________
2004 G35 6MT Coupe/Performance all options-minus nav- Brembos, JWT pop charger, Z-tube, JWT clutch and lightened flywheel, Greddy axle-back exhaust, tein drop springs, MD 5/16 spacer
Old 05-02-2008, 02:38 AM
emtguy05's Avatar
Kevin
I have the EXACT same problem happening to mine. I have an 03 coupe and I have to manually lock it before I get out and than unlock it with the remote and use the key to open the door. How embarrassing using the key!!! That is like soooo 90's!!
__________________
03 Laser Red coupe 6mt|Brembos|Navi|Premium Sound|Spoiler|10% tint all around|USA SPEC Pa11-NIS
Quote:
Go ahead. Skin it. Skin that smoke wagon and see what happens
Old 05-28-2008, 03:41 AM
i had the exact same problem with mine. got it replaced and it works fine, now my gas tanks doin the same thing. anyone else have the same problem with the gas tank?
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
