MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > TSB- Technical Bulletins
Thread Tools Search this Thread Rate Thread Display Modes
Old 04-12-2007, 09:30 PM
Problem with A/C....please take a look
My A/C is doing something unusual.....
On ANY mode its in it blows cold air when set to 60 degrees, however as soon as I turned it to 61 or above it starts blowing as if I have the heat on......
Scenario:
Outside temp is 85 ( i live in FL), inside is set to 60....blows freezing cold. as soon as i bump it up one degree to 61 it blows hot (not just warm) Anyone else have this problem before?
I had sub/amp install at circuit city but they didnt touch the radio, they hooked up a PAC adapter to the rear speakers. Only thing they did electrical was disconnect my battery for an hour or so? Is this related? Thanks in advance for your help.
Old 04-12-2007, 10:05 PM
jjyellow's Avatar
They had to go behind the radio and fool with something. This has been posted before when some did a dd conversion, I believe its a hose or wire harness ,dont quite remember, that got disconnected. I believe its on the driver side behind the radio or under the plastic covering of the steering wheel.
Old 04-14-2007, 02:08 PM
anyone else have know the details about this???
Old 04-23-2007, 02:45 AM
Bing helped me finally solve this mystery. On the panel that is under the steering column, when it is pulled down, you have to make sure that the little white plug on the right side of the panel is connected properly or else you only ALL HOT or ALL COLD. The plug is just located right above that big black rubber tube.
Mine wasn't fully connected and when Bing plugged it in, my A/C worked. I guess that plug connects to the temperature sensor or something.
__________________
2003.5 AT (Desert Platinum) | Premium Package | GroundingGear 10-wire Kit | Stillen Intake w/ Z-tube | MD 5/16" Iso Spacer | Megan Racing Coilovers | Stillen Sway Bars | SPC Front and Rear Camber Kits | Audio System by Simplicity in Sounds | Clear corners | White LED clock lights
Old 06-20-2007, 09:57 PM
Guys need some help here. I'm not getting any cold air and I checked the plug under the steering column and i'm still not getting anything. I checked the AC pipes and they're not getting cold at all (Low and High are cold). Any ideas? I'm thinking the compressor is shot, but i'm hoping its not. I got 62k on my car and i'm sure i'm out of warranty.
Any help would be appreciated.
Thanks
Paul
Old 06-20-2007, 11:44 PM
Tonys-G's Avatar
if you are getting cold air out of the blower then more than likley it is not your compressor, easy way to confirm is go into the engine bay when you have it on 60 degrees when it is blowing cold check the compressor plate on front and see if it is turning, also put your hand on the low side line, it is the fatter(bigger) line it should be cold to the touch
__________________
05 AT G35 Coupe(AB)-28% tint-Brembo Brake swap/SS brake lines/Drilled Slotted Rotors-Volk SF-challenge 18" 9/F 10/R-Relentless front tower brace-Stillen Torque Damper-Stillen F/R sway bars W/Urethane Bushing-SunHyper Grounding kit-Injen CAI-
Old 06-21-2007, 12:38 PM
Correction, Low and High pipes are both Warm. I checked and the plate is switching over and I have the interior setting at 60. I checked both Auto and Manual settings and I'm still not getting any cold air.
I thought it was the freon at first and when I hooked the gauge up on the Low to charge, the gauge read 50lbs OVER! I'm now thinking that whoever owned the car prior to me overcharged the system and blew the compressor. Thoughts?
Thanks!
Paul
Old 06-22-2007, 10:32 PM
Tonys-G's Avatar
what does the high side read?
__________________
Old 07-25-2007, 10:05 PM
don't take me 100% but i think if the freon is overcharged the air is going to be at least warmer than normal.
Old 07-26-2007, 04:01 PM
RBull's Avatar
Runners FTW
Thanks!
Paul
I'm not a tech but used to work in the wholesale refrigeration and A/c business. your gauge sounds wrong. 50lbs over. I don't believe the system could take that much charge. I agree your compressor sounds like it's not working or perhaps one or both of the controls.
G/L
Old 10-19-2007, 10:33 PM
does your compressor turn on? And are you sure that rubber hose is connected under the steering colum? That's usually the problem.
Old 10-19-2007, 11:28 PM
O HELLA OEM's Avatar
Ha[]D[]DY New Years
weird!
__________________
o4 DG G35 Coupe|Axis Reverbs|Fujita|NRG..
Im now SAVING up for a 2008 Infiniti G37S or a 2009 Nissan 370Z!!!
Old 03-19-2008, 02:36 PM
jayjay1122's Avatar
This is mentioned in a lot of places and you posted a while back so I do not know if you have got this fixed yet, but here goes...
If you drop the panel under the steering column (should pull down easily) and look to the right above where your right knee would be, there is a hose fitting and a sensor.
BOTH of these need to be connected!!
If either one is disconnected, you will get ice cold air at 60 and the second you hit 61 it will blast hot air...
Trust me, I have knocked that damn hose lose 20 times when taking the panels off for various reasons and I never realize it till I get a blast of heat at 61 degrees!!
Old 07-24-2008, 10:06 PM
I cant find that plug...can u help me?
Old 11-11-2008, 06:41 PM
AARONHL's Avatar
SIX SPEED SEDAN CLUB
THANK YOU FOR THIS THREAD!!!!!!! The hose needs to be slid on all the way. I am also putting a zip tie around it.
__________________
04 DG G 4DR 6MT
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
