bose amp wiring diagram
Old 02-15-2011, 07:42 PM
zoop425's Avatar
Any one have one or know where I can find it for the 07 sedan?
Old 02-15-2011, 08:50 PM
zoop425's Avatar
ok I found this one..
Should I use the sub + and - or right and left speaker inputs (pre amp) from from the bose amp for the LOC?
Old 02-15-2011, 08:51 PM
zoop425's Avatar
Old 02-15-2011, 09:20 PM
kool_yaar's Avatar
If you are planning to install LOC for sub system then just use this connector and its a straight forward install, i had no probs with my old alpine system.
Itagucci (02-20-2017)
Old 02-15-2011, 09:39 PM
zoop425's Avatar
OOOO you need to use the post amp wire harness that goes to the amp? is that because the bose amp balances the output prior to entering the aftermarket amp? I usually go pre amp (never done a sub in a G though)
Old 03-05-2011, 10:08 PM
synesis's Avatar
Wiring diagram and more
Check your PM. Two links I was not sure whether I could post..
Old 03-21-2011, 09:50 PM
KurTecH's Avatar
zoop, what did you end up using?
i'm looking to do this later this week and was wondering if kool yaar's suggestion worked.
synesis, can you send me the links as well? or just post them here for others to read?
Old 03-28-2011, 07:11 AM
rybo917's Avatar
now for him to install the rem for the amplifier should he connect it to the yellow wire(battery) in the subwoofer wiring diagram above or should he connect it to the infinitis amplifier wire
Old 03-28-2011, 12:33 PM
kool_yaar's Avatar
#4 GR, woofer amp on, else if you connect to battery the amp will always be on even when you turn the car off.
Old 03-28-2011, 01:21 PM
rybo917's Avatar
So u wire the the loc and the rem all through the post amp subwoofer wires? using 1, 2,4?
Old 03-28-2011, 09:12 PM
rybo917's Avatar
and btw i just wired my system by using 1,2 for the loc on the amp and 4 for the rem and no power what so ever
Old 03-29-2011, 09:08 AM
kool_yaar's Avatar
i have rem wired to 4 from what i remember ill have to recheck it but im 90% sure, then the power for amp straight from battery, good ground and then the audio player has to be on and it works fine for me.
Old 03-29-2011, 09:59 PM
rybo917's Avatar
Huh that's what I did but whether or not if that's right shouldn't my amp have power because its connected to the battery Nd ground already? Cause my amp is supposed to light up if it does, but connecting to the battery Nd running the wire is easy
Old 04-15-2011, 12:28 PM
botlfed98's Avatar
good info...thanks!
Old 06-16-2013, 09:07 PM
MikeJones916's Avatar
Thanks Kool you rock.
One more question though.
So from this picture, I am assuming that the image with the 1,2,5, etc... on there, that is the actual connector right?
So when I am looking at those numbers, those are the ports they plug into, and for me installing the LOC, I would be cutting and splicing into the wire associated with that number, right?
Also, schoche told me I should wire their LOC AFTER the amp before it plugs into the sub, does this sound right to you?
Quick Reply: bose amp wiring diagram
