| New! Use your Facebook to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
Tire rotation, best way to lift rear?
Did my first rotation (7500mi) a few weeks back and it was pretty tough raising the rear. Currently, I have this equipment handy:
I drove up the ramps with the front tires, then threw the 2 jack stands under the front axles area, per my usual oil changes, but when I got to the back, I realized it would be pretty tricky. I couldn't fit a standard 2 ton jack under the car from the rear, so ended up elevating from the side lip/flange jack point, then removed one rear tire at a time for the front<->back rotation. Anticipating my next rotation, I'm trying to come up with a better (safer, more efficient) way to lift the rear of the vehicle. I was thinking of investing in another pair of Rhino ramps and 2 more jack stands, so I'd just drive up all 4 tires at once, then insert the 4 stands. A pair of ramps and stands should cost no more than $40-50 off Craigslist, but thinking about it some more, when I replace the tires down the road, I'll be purchasing the lifetime tire rotation package from the local garage/Walmart, so perhaps it's not worth the effort to purchase another set of ramps/stands, not to mention the precious garage space they take up. Any tips from those who do rotations themselves?
__________________
'08 liquid platinum/graphite/rosewood AT, 70% Geoshield/35+20% 3M, daytime running lights, VentureShield, turn signal mirrors, KPT navi interface and window roll-up, debadged |
use the center jack point to lift the front, place 2 jack stands on each side right behind the front wheels
remove center jack jack up rear of the car on each side at the same time with your 2 jacks just remember that the cars balance point is right around where the shifter is, depending on how full the gas tank is. so place the front jack stands closer to the front then that balance point. (fill the tank up to move the balance point closer to the rear). do this on level solid ground and u should be all set
__________________
im an *** hole |
doin the rear is simple. just block the front wheels and jack the pumpkin. both side some off the ground in a second
__________________
I Haz Boost |
Not sure how you expected to rotate the tires while they were on Rhino ramps...but anyway, do what snowcross said. If you want to do a four-wheel rotation (assuming you're not running staggered wheels/directional tires, hard to tell), get four jackstands.
__________________
2003 Emerald Mist/Graphite || Z/Coupe springs||Rays 19s F:245/35 R:255/35||Stillen CAI w/CF tube || MD 5/16" || HR-Y/05 Sdn mid/HKS || Stillen sways || Philips/PIAA 6000K || Bump clears || nismo shiny things|| AMSOIL |
Quote:
Thanks. ----- prech, i don't think you can drive up all four wheels on the rhino ramps and place the stands in their respective locations. What i do in my case is lift the car side-to-side instead of fore/aft. Then again, when i rotate, it's just F<->B so i only need to lift one side at a time. |
Yeah thats what he's referring to. I do something similar to OP. I drive up on ramps for the front and on 2X4s in the back. This makes access easy to jack up the front off the ramps and place stands, then go to the back which is raised a bit on 2X4s to get to the rear pumpkin. I do not have a low profile jack, and I'm lazy/time bound so this route has been quickest for me...... g'luck....
__________________
'08 G35XS .... Blue Slate/Graphite/Washi |
Quote:
__________________
yeah usually use 2x4's if your really slammed, best idea and then jack where the pumpkin is like everyone said. easiest way to do it.
hey soundmike post that link to your super 2X4 ramps those things are kewl, might make 'em someday.
__________________
| Tags |
| g35, jack, points, rotation, tire |
| Thread Tools | |
| Display Modes | Rate This Thread |
