| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
Can i do all 20 X 10 +35mm on the X?
same as the topic.
I'm wondering could the V36 X do all 4 corners with 20 X 10 +35mm like those hella flush STI ![]() ![]() Colour: Machined Black with Chromed Stainless Lip or Machined Black with Chromed grooved lip or Black with Chromed Stainless Lip?? RIMS: 20 X 10 +35 or 20 X 10 +40 or 20 X 8.5 + 35?? Tire: toyo t1 R 245 35 20 or 235 35 20?? Please help me out to complete my car. Last edited by way_boy; 09-28-2009 at 02:23 PM. |
rear i know you wont have a problem at all but 20x10 out front not sure about that
Quote:
since most likely people would only put 8.5-9.5 for the front >< |
Quote:
so i will need to get a camber kit ??? but i know there's only rear camber for the X, so how about the front? and can i run with toyo t1-R 245 35 20 then? |
It'll fit fine with some camber.
If you're going to lower your car a decent amount you probably won't even need a camber kit. H&R springs would give you the camber you need.
__________________
2007 IP G35 Sedan Custom FI Catback|H&R Springs|Bronze Five:AD S5:F 20x9.5 +25 20x10.5 +33
It will fit without any problem.... just make sure you utilize the camber. What are you lowered on?
__________________
= Volk Racing = Kics Project =JIC Magic = GT Spec = Eibach = Takeda = Hotchikis = SxExCx = ARC =
Special Thanks to RareJDM, Asura Design, Dave's Garage, CaSkyline, Riverside Infiniti, Limited Edition, Auto Explosion, and Amplified Motorsports |
I dont worry about the rear, Im just after the front will have rubber issue
I wonder what the heavier and wider front wheel/tire combo would have on steering...
__________________
2007 LP/stone G35 Journey l Sevas S55's l 35% tint l paddle shifters l 6000k HID headlights l 3000k foglights l Fujita intake l V1 l Nissan Front lip l |
Quote:
but I dont mind it heavier because i used to drive a 02 mini with 18 X 8.5 on it with electrical steering which my Gf hates the most haha I'm just afraid of the front sticking out way too much with a 10 instead of 8.5 |
If you're going to stretch your tires, why would you worry about performance? Stretch tires = negative on handling.
__________________
I dunno if this is helpful for you but I drive an X as well.
I have rims on order right now. The size is 20x9 +38 all around.
__________________
07 G35x. OB. 20% Tinted. 3M Clearbra. White L.E.D's. Stillen Catback Exhaust. Bat's GTR Tailights & Valance. Black Grille. Custom CF Interior. CF Black Betty. Sport Paddles. RacingBrake. GTSpec STB. Nismo Chin. Eibachs. Coming soon:Forgestars F14's/Hankook Ventus V12. |
Quote:
So, i just need someone to tell me +20mm will work fine ... |
Yeah that'll also fit fine.
__________________
I fit 10 with a +30 offset up front on mine, you would need a bit of camber....I'm not sure how low you are going but it will look great.the rim came really close to the control arm but i would say there was at least a 10 mm gap in between the two. I'm not sure if X control arms are the same but you should probably find someone with close to that spec wheel to test them. They work fine on RWD models
__________________
"Nissan" Raping Face Since....1969 |
| Tags |
| 10, 20x10, 20x1010, 2353520, 95, 96, camaro, front, g35, g35driver, g37, offset, rim, sedan, size, wheel |
| Thread Tools | |
| Display Modes | Rate This Thread |
