MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > G35 Sedan V36 2007- 08 > Tech V36 Sedan > V36 Brakes, Suspension, Wheels & Tires
New! Use your Facebook to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 11-02-2009, 01:33 AM
Question brake pad replacements
what is a good brake pad for the 08 g35s other than original. hawk used to make pads for g35's, but the s model has bigger rotors.
any suggestions? cost??
Old 11-02-2009, 08:45 AM
Different calipers, too.
I believe Hawk does have HPS for the 07/08 S models now, as does Raybestos (same company). Carbotech also has a variety of pads available, most made to order.
Old 11-04-2009, 01:57 PM
2007 Infiniti G35
just curious, what is the difference in size between the S and non S? will the Akenobo calipers fit on the S discs?
__________________
2007 PG/G int. G35S 5AT nav, tech, premi. F.I. catback, BBGK
Old 11-04-2009, 02:07 PM
Kris79's Avatar
battle froggy
2004 Infiniti G35
project mu makes a nice pad.
__________________
Thank you for the support/sponsors
Our*Garage/MACH III /Full Function Tech ~Dpe Wheels~ Mackin industries ~ Pro-motion ~D sport mag~TnT Autobody~ Devils own ~
Hikkatadori Aero kits<-- who needs body kits!?!?!
Old 11-04-2009, 03:39 PM
Quote:
Lots. The S (07/08) has larger and thicker rotors and a different design for the calipers (single larger piston up front). Complete specs is on p. 62 of the "BR.pdf" file of the FSM.
The Akebono-equipped Sport uses an even larger rotor still, the caliper will fit over the smaller "S" rotor from above, but there's going to be lots of overhang and the pads will be loose. Yes, it will fit, but it won't work.
Old 11-05-2009, 02:16 AM
thanks!
the S has larger rotors. about the fitment u mentioned - i have no idea.
love to read from somebody who knows!
jimk
Old 11-05-2009, 08:06 AM
Administrator
2008 Infiniti G35
Quote:
I've seen these mentioned a lot lately, but haven't seen any real comparisons.
How do they compare with HPS etc?
__________________
'08 G35S 6MT - back to OE, this sig is getting shorter ►►║DPE-R16║IGT Carbon Fiber Interior║Sport Lip║Inter.LEDs║Stillen Sways║B.Dog║Splash Gards║◄◄
Old 11-16-2009, 09:49 PM
how long did you guys wait until you changed pads?
Old 12-03-2009, 04:01 AM
Send a message via AIM to Rottten Appples
Quote:
really depends on how hard you drive/brake.. driving style.. i run through pads within 6-7 months.. approx 2500 miles a month, but have found hawks to hold up pretty long (9 mos. ish?) heard some things good about project mu. check em out.
__________________
B/O 09' G37s 6MT Sedan, OEM lip, Greddy Spectrum Elite, Tein S-Tech, Volk GT-30 Phantom..
Tags
08, 2007, brake, check, cost, forums, g35, g35s, hawk, infiniti, pad, pads, replacement, sedan, sport, v36
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive -
Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
