Wheel/Tire Sizes 2007 G35X
I am in the market for new wheels and tires. The stock wheels are 17" with 225/50 R17. I would like to go 18" or 19" but am not sure on the wheel sizes and offsets. I am also worried about ride quality. How much does a low profile tire effect the ride?
The car is not lowered and I was wondering what it can put on it without rubbing.
Also would like to know what the weight and offset is on the stock wheels.
Any suggestions on wheel and tire sizes?
The stock wheels size for an 07 G35x should be 225/55-17. Someone put the wrong size tire on there. To small. Your speedo would be off an extra 3.3% and thats not good considering many off the X's are already inaccurate with the correct size. Mines off 5-8% depending on my speed.
Like RBull says, you are going to be a long way from rubbing especially with our factory springs and wheel clearance. Your circumfrence is almost identical to factory specs.
use this - http://www.miata.net/garage/tirecalc.html
Ive been keeping off the forum purposely to keep the mod bug at bay. Its worked. But now that ive been back again *sort off*, ive been thinking about mods again! AAHHH!!! I N E E D T O S T A Y A W A Y!!!
hope things are well with you!
Hello all,
I have been on the forum for a while now haven't said much just been doing research and came across this thread. I finally have some $$$ to spend on mods my wheels just came in specs are 18x8 +45 5x114.3 all four. I plan on getting all season tires just not to sure on size I drive a 2007 g35x any help would be much appreciated thank you for your time.
