Another rim/wheel fitment question?
I have searched and searched and still haven't been able to find the exact answer, so I have to ask
I have a 07 sedan sport. I am looking at running the following in the near future, please let me know if this will work without rubbing and the lowering springs.
Front-19x9.5 +45mm with 235/35R19
Rear-19x9.5 +45mm with 275/35R19
I have found mixed answers on this, but nothing concrete. I would like a flush look and was thinking of getting either the Eibach Pro kit or H&R Sport Springs. I DO NOT want to roll my fenders if I can help it. Do I need spacers to help?
Thanks in advance for any help/advice!
Cheers, Lynxs
Cheers, Lynxs
Cheers, Lynxs
Cheers, Lynxs
Be sure to use this calculator when sorting through compatible tire sizes, you really want to be as close to zero as you can +/-1% is great.
http://www.myg37.com/forums/tire_rim_calculator.php
lynxs961 (12-07-2013)
It will work but you'll have a stretched fit in front and an optimal fit in the rear, you'll also have smaller diameter in front w/ the 35 rather than 40 sidewalls, the fronts should be 40 the wider rears 35s for the same diameter all around, if that doesn't matter to you than run the 35s on front too.
