| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
DIY: Grille Removal
Tools needed:
8mm socket 10mm socket Socket wrench Flathead screwdriver Guide: Red - Flathead screwdriver Blue - 10mm socket Yellow - 8mm socket Green - pinch and push out White - push out Front end ![]() First remove all clips circled in red with flathead (6 total), also remove all 10mm bolts circled in blue (10 total). ![]() clips circled in red upclose ![]() FYI: There are two 10mm bolts that are covered by rubber, pull back rubber and remove bolts Left side (looking head on) ![]() Right side (looking head on) ![]() At this point you should be able to lift the cover up like this... dont lift it too much as it is still attached by 7 pinch and push clips (circled in green) and 2 push clips (circled in white) ![]() Lift enough to reach in and undo the 7 pinch and push clips (circled in green) and the 2 push clips (circled in white) ![]() Once all clips are removed it should lift up like this... ![]() Removing this 10mm bolt and turning the reservoir away makes its easier to remove the plastic piece wiggle this plastic piece out as it is now free... looks like this.. ![]() Top view ![]() Now reach in and loosen the 5 8mm bolts (circled in yellow) ![]() ![]() Next pinch and push 4 clips from the inside of the grille, top and bottom X2 (circled in green) ![]() once completed it should look like this... ![]() In total when removed you should have: 6 clips (circled in red) 10 10mm bolts (circled in blue) 5 8mm nuts (circled in yellow) To put everything back together do the whole process in reverse... Good luck!
__________________
04 IP G35 Coupe with a few mod's|05 S2K NFR with a few mod's|SFL G Club
repainted my grille gloss black instead of ultra flat black in picture #1.
![]() ![]() and the last one just because i love looking at my car!
__________________
Nice DIY! Sticky please!
You are the man, Awesome write up!!!!
Could you elaborate on the process related to sanding, priming and painting? What brand / color paint did you use? Also just need to find time and better weather before I do this mod. Last edited by 07 G35S Sedan; 02-22-2008 at 07:52 PM. |
Soooooo much room for an intercooler.
__________________
07 6mt Sport Sedan, Diamond Graphite/Charcoal, 20" I-forged (sold),18" Volk TE-37's (sold) , Eibach springs/camber kit 07 Armada LE 4x4, Pebble beach/Charcoal |
Nice! Thanks! I plan to swap out and install a new OEM grille in a few weeks.
__________________
'07 G35X @ 27K miles |
save pics and sticky?
__________________
2007 LP/stone G35 Journey l Sevas S55's l 35% tint l paddle shifters l 6000k HID headlights l 3000k foglights l Fujita intake l V1 l Nissan Front lip l |
I used Dupli color ultra gloss black and dupli color color match clear coat. 4 layers of black and 8 coats of clear.
__________________
07SilverG,
Very nice DIY. When I attempted to do this before, there were 2 screws that blocked me from lifting the piece (pic #6). I even removed the white reservoir (pic #9). I've attached a pic of which screws I'm talking about. I cracked my cover, so I gave up. How did you past these? Just by wiggling the cover?
__________________
2008 G35x with premium and wood |
Quote:
__________________
DYI Sedan Grille R&R.....!
Great DYI post, that's just one of the advantages of belonging to Driver....
KNOWLEDGE
__________________
'04 G35C "Twilight Blue" Volk SF Winnings/Michelin PS2/Stillen Sways/SPC Endlinks/Richie Strut Bar/Tein H-Techs/Bilsteins/Nismo Diff Cooler/Stillen CAI+Z-Tube/MD 1/2" Spacer ISO/Polished Plenum+PS Tank/HKS Exhaust/Gordee Grounds/KurumaZ Bumper/Impul Sides/JDM Clears/Tint/CFZ Engine Cover/Red Line |
I decided to go ahead and swap in my new OEM grille this morning.
Not sure if this is because I have an X but I only had to remove 7 (10mm) bolts to remove the top cover. I also removed the 2 (10mm) holding the coolant recovery tank in. It just made it a lot easier to get my hand in there since there are a couple pins that hold cover in place that you have to pull rearward to remove that end of the cover. In addition the nuts that held my grill in place were 10mm instead of 8mm. I would also have some narrow needle nose pliers handy to release the clips. This makes that process fairly easy. I just used the flat nose screwdriver to release the clips holding the hood release cable in place. All in all pretty easy and only took me 15-30 minutes.
__________________
great job on the grille and DIY!! plan to do mine once it gets warmer.
Quote:
i only used 400 grit sandpaper to sand it down until all the chrome was off and it became white, if you start to get to deep it starts to turn black. stop sanding that area of that occurs. it takes a little effort because of the angles you have to get into towards the sides. i sanded it by hand and couldnt see how it could have been done nicely with a power tool. i sprayed one coat of dupli color primer, layed down 4 layers of glass black and 8 layers of clear, let it dry for 2 hours and reinstalled.
__________________
| Tags |
| 2007, armada, bumper, clip, diy, front, g35, g37, grill, grill removal, nissan, removal, removing, sedan, tool |
| Thread Tools | |
| Display Modes | Rate This Thread |
