MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > G35/37 Sedan V36 2007+ > Tech V36 Sedan > V36 DIY
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 03-01-2009, 06:44 PM
DIY: Fix your scratched shift knob 07+ Sedan
I had a few minutes today and decided to fix my scratched shift knob. I know a few of your have had the same problem with scratches in the aluminum trim on the 07+ sedan shift knob. It's a super easy fix.
Grab the aluminum trim ring on the shift boot and pull down. Expose the wire clip and pull it towards you to release, then lift knob straight off.
Next grab some blue painters tape and mask off the leather, leaving the aluminum trim piece exposed:
Grab a green scotch brite pad and "with" the brush marks rub using light to medium pressure to remove the clear top coat. Once you get all of the clear coat off "palm" the scotch brite pad and make long back and forth passes over the trim piece (not short choppy strokes). This will leave long perfect brush marks on the trim piece:
Next give it a good wipe down to prep for paint. I used Dupli-Color Auto Spray "Clear Top Coat" and gave it two coats and called it a day:
20 minutes later I installed it to let it dry. I'll give it a blast of air from my air compessor tomorrow to get out any sanding dust and wipe down the leather. Good times!
Old 03-01-2009, 07:10 PM
2007 Infiniti G35
My Garage
AWESOME!!! i am so doing this next weekend.
__________________
07G35Sport- Check out my http://www.cardomain.com/ride/3226086 for mods/pics.
Old 03-01-2009, 07:11 PM
Great solution and write up man,
Thanks!
__________________
07 G35X Black Obsidian | 20% Tints | Iforged Estoril | Eibach Pro-Kit |
Old 03-01-2009, 07:45 PM
InTgr8r's Avatar
Administrator
2008 Infiniti G35
Great job
__________________
'04 G35 Sport 5AT »» '06 ///M Z4 »» '08 G35S 6MT
Old 03-01-2009, 08:28 PM
kregg's Avatar
2008 Infiniti G35x
Good Idea!!
__________________
[ '08 G35xS Blue Slate/Graphite/Washi.... Prem./Spoiler
Old 03-01-2009, 08:41 PM
Capthook's Avatar
Send a message via AIM to Capthook
I love this! Great work
__________________
08 OB G35S Prem | SF Challenge 19x9.5 +28 & 10.5 +23 | Eibach springs |
Old 03-02-2009, 06:05 AM
It is not going to work on mine since it is deeply scratched into the plastic layer. I don't think there is an easy way to fix it. I just place my hand on it all the time and hoping all the left over aluminum paint will go away so I will have a solid white plastic knob. lol
Old 03-02-2009, 09:27 AM
InTgr8r's Avatar
Administrator
2008 Infiniti G35
^ you could paint it instead of using clear coat.
__________________
Old 03-02-2009, 11:03 AM
Quote:
I heard someone say it has a very thin coat of Aluminum over plastic. Honestly it felt like solid aluminum to me. But yeah it could be painted in a chrome paint and brushed with very fine steel wool, then cleared. You could also paint it black or body color. If that piece comes out I'd replace it with a piece of Bubina (african rose wood) to match my dash. If any one has removed that piece post details here.
Old 03-02-2009, 02:54 PM
johnnyzee's Avatar
2008 Infiniti G35x
sweet!
__________________
... Rockin' a white, dropped, '08 G35X on 19"s
Old 03-02-2009, 03:09 PM
Good write up! Looks good!
__________________
05 DG 6 M/T | NAV | Axis Shines | Nismo | Falken | Injen | XO2 | Top Speed | Hawk | Nokya | Blue_bat
Old 03-02-2009, 04:59 PM
I would like to know if that plastic piece can be detached from the knob. It would make it much easier to sand and paint it. If there is a real aluminum piece, it is great to replace that little cheap part.
Old 03-03-2009, 03:12 AM
take off your knob and look inside. If there is a screw inside yes you can remove it. I sort of doubt it though. It is probably pressed in with small clips. Taking it off (prying with a small screw driver) will probably mangle the piece. If you mask it off really well there is no need to remove it.
Old 03-03-2009, 11:02 AM
djwishuwur's Avatar
2007 Infiniti G35
Send a message via AIM to djwishuwur
What do you have to do to make this a sticky? This is worth adding to the list. Well done.
---Matt
Old 03-10-2009, 08:47 PM
Just did it using your DIY. Worked great. I had some pretty deep scratches that I couldn't fully get out, but it looks a million times better now. Thanks.
Tags
07, diy, g35, knob, scratch
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
