DIY: check engine / service engine soon light from HFC fix
Old 05-20-2009, 09:46 PM
suby01's Avatar
Step by step on how to get rid of check engine/service engine soon light after installing high flow cats or test pipes.
-purchase spark plug anti foulers at your local auto parts store
-will need 4 total 2 for each sensor
-18 mm size
-made by HELP brand / part number 42002
-disconnect the negative terminal on your battery
-take one of the anti foulers and drill out its center using a 1/2 bit
-this will increase its hole size and allow your stock o2 sensor to fit
-when finished this is what it will look like
-side by side comparison of the original and now modified non foulers
-screw the drilled spark plug anti-fouler on top of the original
-be sure to use some kind of anti-seize on the treads. in case you need to remove your fix with ease
-unscrew your stock o2 sensor and place your cel / ses fix in
-use anti seize on the threads
-o2 Sensor inserted in the modified non fouler
-unmodified non fouler now installed on modified non fouler
-original non fouler->Modified non fouler->o2 sensor
-reinstall your o2 sensor
-reconnect your battery and do a ecu reset
TxPwnBoy (03-01-2014)
Old 05-21-2009, 01:24 AM
G35Robby's Avatar
Nice write up
Staff, please move this to the DIY thread.
Old 05-21-2009, 11:23 AM
kool_yaar's Avatar
nice detailed write up suby, do check back in about of week of driving and let know if anymore CEL plz. now i MIGHT consider getting some HFC's and the cobb with stage2 map which supports hfc, catback and intakes!!
Old 05-21-2009, 11:44 AM
suby01's Avatar
i had that for over 6 months now and its allllllllll good, first i had just one and it came back every 500-1000 miles just reset and it was good for a month or so, but then i heard about doing two of them and like i said 6 months++ and no problems. and hope it stays that way.
Old 05-21-2009, 03:06 PM
kool_yaar's Avatar
nice thanks for that. also do you have any hesitation problems and such due to the HFC like some others had?
Old 05-21-2009, 10:06 PM
earth0's Avatar
Nice!! and Thanks for DIY.Wow, Sticky plz!!!!!!!!!!!
Old 05-21-2009, 10:09 PM
earth0's Avatar
Lucky I have no CEL light on mine BERK yet.It's been over 1 yr and 2 months now.I will keep mine finger cross.
Old 05-22-2009, 11:40 AM
Defratos's Avatar
You're Despicable
^ mine's only been on for a month, so far no problems but I don't want to have to try and source those here
Old 05-22-2009, 12:08 PM
ketchupfreak's Avatar
Same here
Old 09-27-2009, 05:45 PM
elperuano's Avatar
good to know, quick question went to discount auto n they have this product 18mm in size but part #42009... Does that make a difference or can i still buy it? Also is it ok to drive with the service engine soon light on?
Old 09-28-2009, 11:40 AM
4drsleeper's Avatar
Stillen sent me the spacers for free after my SES light came on.
Old 10-07-2009, 12:43 PM
suby01's Avatar
yup you gotta call and complain to still and they will send them to you. i think they should already include it with the hfc. but just another way they are trying to cut back, but the stillen one still caused a ses light for my car. so i found this way that works.
Old 10-10-2011, 05:45 PM
botlfed98's Avatar
good info! thanks.
Old 10-24-2011, 10:59 AM
Cabos G35 Coupe's Avatar
Good stuff I just installed my berk hfc last week and my engine light is on ima try this when I have time thanks for the diy
Old 10-26-2011, 08:43 PM
Feeelax's Avatar
Was hesitant to buy HFC's but thanks a bunch for this write up
Quick Reply: DIY: check engine / service engine soon light from HFC fix
