DIY: NiftyShifty Automatic Shiftboot install / OEM Boot Replacement
Old 07-14-2010, 12:03 PM
Locksmith's Avatar
Hey guys! I finally got around to finishing up this DIY to show how to replace your oem V36 Automatic shift boot, follow the steps at your own risk but if you do it all correctly the install shouldn't be too hard. Heres the steps..
FOLLOW those steps and you should be able to put on the new boot to replace the crappy vinyl OEM boot with new leather, suede, vinyl, or carbon fiber.
Old 07-19-2010, 08:55 PM
Greekboy115's Avatar
Thank you for the write up. Very easy to follow and good pictures showing everything that you need to know.
Old 08-14-2010, 04:17 PM
Q8y_drifter's Avatar
awesome!
i'm gonna need this when I get my boot. I wanna swap the stupid wood finish to the aluminum too
Old 06-09-2011, 01:26 PM
GXXXV X's Avatar
is this pretty much the same process to install the BIG shift boot?
Old 06-09-2011, 02:48 PM
Locksmith's Avatar
Very close, instead of swapping the oem tiny boot you just take it off, remove the shifter panel with the p,n,r,d from the center console and put the boot around it then put it back together.
Old 06-09-2011, 03:00 PM
Locksmith's Avatar
Old 07-27-2011, 09:17 PM
djfarhan's Avatar
thanks for the write up!
Old 07-27-2011, 10:06 PM
Locksmith's Avatar
No problem!
Old 10-10-2012, 08:21 AM
Endro's Avatar
do you have a suggestion on how to secure the top of the boot up against the killjulez ****?
mjfenix
08-17-2017 05:49 AM
xluke
07-30-2016 01:48 PM
bTanz
10-15-2015 02:31 PM
Buggzb86
Drivetrain
07-25-2015 11:22 PM
Quick Reply: DIY: NiftyShifty Automatic Shiftboot install / OEM Boot Replacement
