DIY: Change/Dry Out Your Headlight Ballast
Old 04-13-2014, 05:08 PM
RemmyZero's Avatar
I apologize in advance because I really should have done this last year because I'm sure a lot of you need it. I hit a dear about 12-13 months ago and after having the car repaired as soon as it rained my headlight went out. I argued with the insurance company that the damage cracked the headlight but they just didn't care. My last resort was to remove the ballast, disassemble it and dry it out. I even had an issue where I bought a new ballast and it still didn't work because the headlight harness was waterlogged too. Oh well. So this should work on 2007 through present G35/G37s. It's not hard just takes some time. As always i'm not responsible for any damage you do to your vehicle but this is easy enough that you shouldn't have to worry.
Essentially you only need a small flathead screwdriver (for removing the plastic clips on the fender liner) a long phillips-head screwdriver and a tamper-proof torx bit for opening the ballast (I bought these at autozone).
Peel back the fender liner (I took the tire off to make life easy).
Unplug the harness from the ballast
Now there are three screws holding the ballast in. Two in front and one in back...here are the front two. You can't see the other one but it's in the same place on the opposite side.
The back one you can't see but you can still access it with the screwdriver (this is where the extra long screwdriver comes in handy). It's a bit of a pain to get this one out but still easier than removing the headlight. You'll notice it's towards the engine, not the fender.
Pull the ballast down and carefully unscrew the retainer clip and unclip the harness.
At this point I turned the ballast over and maybe 2-3 full tablespoons of water came out so it was obvious there was a short circuit in there. I opened it up and carefully dried it out with a hair dryer. Don't concentrate heat in one place too long because there's a chance something in there could warp or get damaged.
I let it sit out for another hour or so then I put the cover back on and caulked the opening around the harness plug
I reinstalled it in reverse order and everything has been fine since and it's been over a year. To make sure I didn't flood the headlight though I drilled 3 weepholes in the bottom of the housing before putting the ballast back in. I don't have pics of this but it certainly solved my issue.
Hopefully this will help some of you now that the rainy season is here.
- Bob
The following 2 users liked this post by RemmyZero:
johnnyzee (04-17-2014), vqsmile (08-22-2015)
Old 06-01-2014, 11:22 PM
takeapieandrun's Avatar
Thanks for the guide. You think an aftermarket ballast would fit in there? The reason I ask is for upgrading to a 55W HID kit.
Old 06-04-2014, 09:15 AM
RemmyZero's Avatar
To be honest i'm not really sure. I have to believe you can make it fit but you may have to get crafty with how you mount it.
Old 06-21-2016, 02:21 AM
rmacinni's Avatar
shot in the dark as this thread is old, but what kind of drill bit did you use to take out the 3 screws holding the ballast cover on? I dont have anything that fits in these screws
https://i.imgur.com/ib7uVV6.png
Old 08-17-2016, 12:14 PM
RemmyZero's Avatar
I already replied to this one via PM but for anyone who wants to know it's a security torx bit. I bought a whole set at autozone but you can get them in other places too.
Old 08-07-2017, 08:42 PM
Skaps6900's Avatar
Thumbs up G35 ballast
Any recommendation on brand or OEM ballast. Have an intermittent working ballast. Worked for a year, on and off for a few weeks, then working normally now. Tried new HID and not the prob. Thanks for all you have posted
Old 08-07-2017, 08:51 PM
cleric670's Avatar
BANNED!!!
Received 2,456 Likes on 2,150 Posts
Coupe 6MT Premium RAS
I'm not 100% sure but I see the names Matsushita and Morimoto pop up a lot.
Serge Mullen (02-11-2023)
Old 08-07-2017, 10:29 PM
Urbanengineer's Avatar
Received 1,016 Likes on 935 Posts
You can buy refurbished Matsushita for $50 on Amazon and brand new Morimoto 35W for around the same price.
Old 04-20-2020, 07:23 PM
Persaud Anthony's Avatar
Infiniti g37x
Ballast
whats the name of that plug on ballast?
Old 04-21-2020, 05:30 AM
Scorpi0's Avatar
Butt plug.
Old 02-11-2023, 09:17 PM
Serge Mullen's Avatar
Just an FYI to anyone considering doing this.
These steps will ONLY work for the Drivers side. To remove the ballast from the passenger side the bumper must come off due to no access to the last screw holding the ballast. (windshield washer bottle etc)
I used a $45 dollar kit off Amazon that had good reviews, includes ballast, igniter and even a spare el-cheapo bulb thrown in which was a nice unexpected bonus.
jeffbdye
06-01-2018 03:51 PM
Picture Share
02-04-2018 12:41 PM
9tray turbo
09-29-2015 10:22 PM
Batfinity
Lights
09-27-2015 12:29 AM
Quick Reply: DIY: Change/Dry Out Your Headlight Ballast
