Z1 Hub Centric Wheel Spacers & Extended Studs
Our Hub Centric Wheel Spacers with Extended Studs are CNC Machined from Billet Aluminum and are perfect for achieving that flush look. Available in 5mm, 10mm, 15mm, or 20mm, these spacers should suit any of your wheel spacing needs. If you require something in between the spacer sizes here, we also sell 2.5mm Hub Centric Wheel Spacers which can be used in conjunction with these spacers and extended studs.
Our 5mm Hub Centric Wheel Spacers remain flat to allow the hub center to protrude for centering of Hub Centric wheels whereas our 10mm, 15mm, and 20mm Hub Centric Wheel Spacers all have an extended hub portion to allow for centering of Hub Centric wheels.
Kit includes:
(2) Hub Centric Aluminum Wheel Spacers (Your Choice of 5mm, 10mm, 15mm, or 20mm)
(10) Extended Wheel Studs (10mm longer than stock for 5mm and 10mm spacers, 20mm longer than stock for 15mm or 20mm spacers)
*ARP Studs are offered as an option*
This kit can be found Here.
We also offer Bolt-on style Wheel Spacers. These bolt-On Wheel Spacers are CNC Machined from Billet Aluminum and are perfect for achieving that flush look. Available in 20mm, 25mm, or 30mm, these spacers should suit any of your extreme wheel spacing needs.
Our Bolt-On Hub Centric Wheel Spacers all have an extended hub portion to allow for centering of Hub Centric wheels.
Whats Included:
(2) Aluminum Hub Centric Wheel Spacers with Studs Installed (Your Choice of 20mm, 25mm, or 30mm)
(10) Nuts to attach spacers to existing studs on vehicle
More info can be found HERE
New stud options available.
Kit includes:
Whats Included:
