MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Brakes, Suspension, Wheels & Tires > Wheels & Tires
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 05-12-2009, 01:20 PM
Fat rear tires
I was thinking about getting some more aggressive rims and tires.
Thought about going with some nice fat tires in the rear but physics tells us that friction is independent of surface area
friction depends on the weight of the car not surface area
so fat tires will be just as effective as skinny ones
however, supercars have really fat rear tires
so whats up?
someone needs to explain this to me bc i cant find anything on the internet
Old 05-12-2009, 02:18 PM
redlude97's Avatar
You are oversimplifying the problem. You have to consider the change in the contact patch as the car moves dynamically. Read up on slip angles, then post back
__________________
06 6mt Diamond Graphite G35 Coupe
Parting out:PM me!
Old 05-12-2009, 04:42 PM
im still not seeing how that has anything to do with the traction
it doesnt matter how much of the tire is in contact with the road
or what part of the tire is in contact with the road
its all about the weight pushing down that determines how much friction you get
and how much traction you get
maybe my logic isnt right?
Old 05-12-2009, 04:56 PM
redlude97's Avatar
did you do ANY reading on the subject?
__________________
Parting out:PM me!
Old 05-12-2009, 05:35 PM
yes i did
but i dont think you know what youre talking about
because you cant seem to explain anything
Old 05-12-2009, 05:47 PM
redlude97's Avatar
Then if I don't know what I'm talking about, please enlighten us on your vast knowledge on the subject. Once again, you are over simplifying the problem
__________________
Parting out:PM me!
Old 05-12-2009, 06:13 PM
Send a message via AIM to Sbeck
Wider tires = more contact patch
more contact patch = more traction
Go ahead and make your car heavier.....we will all sit here laughing. It's not like the G35 is heavy enough...right
__________________
05 BS coupe -- HKS HI-Power Ti . PIAA SuperRozza 20x9 20x10 . Yokohama Advan Sports 255/30/20 285/30/20 . BC Racing Coilovers . SPC Rear . 06 Projectors . USA-SPEC PA11-NIS Ipod Integration . JDM Clear Corners
Old 05-12-2009, 06:20 PM
no thats not how friction works
friction is dependent on weight
not surface area
therefore
more contact does not equal more traction
thats why race cars have wings and not tires that run the full width of the car
im guessing that wide tires have some effect but no one can offer a logical explanation of why
Old 05-12-2009, 06:30 PM
mr.stealth's Avatar
so why do fwd drag cars have huge drag slicks while at the same time keeping the car as light as possibly keep in mind weight is also transfered toward the rear during accleration.
__________________
"Do it right the first time"
Old 05-12-2009, 06:32 PM
redlude97's Avatar
Conventional concepts about coefficient of friction are thrown out the window when you are considering materials that are not infinitely hard and abrade due to the friction between the surfaces
__________________
Parting out:PM me!
Old 05-12-2009, 06:36 PM
Taken from post #6 in here: http://www.autocross.us/forums/index.php?showtopic=4410
For the same vertical load and internal pressure, a tire with a wider tread has a shorter, wider contact patch than a narrower tire. The area of both contact patches is the same if the internal pressure and the load are the same. . . A shorter contact patch at the same slip angle begins to slip at roughly the same distance from the leading edge as with a long contact patch. But the shorter contact patch has more of its length stuck to the road than the longer, narrower contact patch; and therefore a larger portion of its overall area is gripping.
And here's basically the same explantion but with some visual aids: http://stockcarscience.com/blog/inde...009/03/22/p108
Old 05-12-2009, 06:37 PM
Send a message via AIM to Alan
Quote:
incorrect. its downward force. weight is one source of it because of gravity. look at an F1 car. very light, tons of downforce, tons of grip!
__________________
Old 05-12-2009, 06:38 PM
haha no
im not talking about the material
im talking about the width
say you have a G35 with super fat tires
and the same G35 with skinny tires (both made from the same material)
technically, according to the laws of physics, you will get exactly the same amount of friction
and therefore the same amount of traction
but supercars and race cars have fat tires
why?
i dont know maybe we'll never settle
Old 05-12-2009, 06:40 PM
ohhhhh
CalsonicVQ
youre right
thanks dude
i see now
everyone else read that
its all about the amount of time the tire is in contact with the road
wide tire=longer contact
=more traction
Old 05-12-2009, 06:46 PM
redlude97's Avatar
haha no
why?
For perfect surfaces interacting with no change in surface characteristics due to slip. Like I said, you are oversimplifying the problem
__________________
Parting out:PM me!
Tags
fat, g35, rear, tire
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
