20x9 What is the correct tire size??
Old 07-29-2015, 05:39 PM
vitamin.v's Avatar
Hello all, so i have 20x9 rims with tires that i bought used but the tire size that are currently mounted is 225/35ZR20 all around. Not sure if those will look small.
I need to replace 2 tires and was wondering if i can go a different tire size that is more fitted with the G.
If the rims are all 20x9, would it be bad if i staggered them? (I am putting a 38mm spacer in the back)
For Example: would 275/45/20 work for the rear without being stretched?
Old 07-30-2015, 02:26 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
What car do you have?
Old 07-30-2015, 02:43 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
It might work, but you will lose a lot acceleration due to the massive increase in rolling circumference.
Old 07-30-2015, 02:52 PM
Texasscout's Avatar
Old 07-30-2015, 11:33 PM
vitamin.v's Avatar
I have a 2005 g35 coupe, what would you recommend in tire size for the 20x9 rim?
Old 07-31-2015, 03:42 AM
Tyke420's Avatar
You need to go with 245/35 in the rear.... If you want to go 275/35 then you need to buy new front tires that are 245/35... If your on a budget, which it totally sounds like you are, just buy 245/35 for the rear and you will be fine.. That's my opinion BTW....
Old 08-06-2015, 07:52 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
We would run 245/30-20 front and 275/30-20 rear.
Old 08-06-2015, 08:30 PM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
There's your answer! ^ You could run the 225s in front for a while, the 245s will give you much better control at speed...Gary
brads350gt (11-07-2019)
Old 11-07-2019, 06:10 PM
brads350gt's Avatar
3.9s-2.8k stall-transgo-cosworth heads-jwt cams-UHP tires-best bolt ons-ITBs-LS2 coils-V8 Killer-
I love my Michelin Pilot Sport AS 3 plus's. 245/40ZR17 front & 255/40ZR17 rears over my old 245/50R17s all around I feel a huge difference in handling, control, acceleration, grip, & stability on my lightweight 17"x8"s. I agree with Gar' and Tyke420, in your situation I would go 245's in the rear and call it a day. They should yield to you all the benefits I just described on your set-up and the best all-around performance for the street.
Footballmania32
19 Inch
06-02-2018 07:31 AM
paolojericho11
09-11-2015 07:08 AM
Jnm07
08-06-2015 03:03 AM
reaper76
08-05-2015 10:13 AM
CrazyLogic219
07-23-2015 10:58 AM
Quick Reply: 20x9 What is the correct tire size??
