3M LCD Screen Protection Film
http://www.activetechdesigns.com/7722.html
Received 2,456 Likes
on
Coupe 6MT Premium RAS
You can order touch-screen protective glass screen in any size you want, measure your display and order the size you need. Be sure to order one with 9H hardness tempered glass with a 2.5d contoured edge, preferrably with an olyphobic coating.
Tips for installing it are to remove the HU (preferrably you would install the screen protector prior to installing the unit) run your shower with the bathroom fan off until the room is slightly foggy. Dust particles become too heavy to float and will settle on flat surfaces so you never have to worry about little lint pieces landing on the screen or sticking to the tempered glass protector prior to installing. Clean the screen thoroughly, align one edge, keep the other side gently lifted by keeping just your fingernail under the edge, work the bubble out from one side to the other and slowly allow the protector to settle onto the screen. If it develops a bubble then slightly lift on the edge that's still lifted and work that area a little better. Slight pressure from your fingertip is all that's needed to get it to adhere.
RemmyZero
V36 DIY
04-23-2018 11:13 AM
Mad A
Not G35 Related
12-08-2015 01:45 PM
