DIY: Cancel Airbag Light (Proper Way) and 07 Weight Sensor Bypass
Wanna thank Riley for this write up! I know he's not on here much anymore, but props gotta be given for all the help this thread has been! I have an 05' Coupe, and needed to do the burrito trick to clear the Occupant error code. Got my da*n SRS light to stop flashing finally haha!!
-Terry
-Terry
I did mine it works like a charm if I could suggest buy yourself a few extra of those resistors in case you have any issues with doing to youR install.
Also a few weeks after install the SRS light came back on because of o loose connection. So had to go all the way back to the electronic store.
#30
i did a bit more searching and found the manual here, http://www.nicoclub.com/FSM/G35/Coupe/ , pick the year you need then click srs
lsmooth81 (11-27-2012)
