Metra's Dash Kit - Rubber Button
Hi,
I'm going to give up my manufacture head unit (cd got stuck) and go for DD. The only thing i don't like about Metra's DD dash kit is the rubber button. Is that possible to replace this rubber button by the button from my existing manufacture head unit? For your info., my 03.5 without dual climate control. Thanks. :) |
No not possible.
Originally Posted by endleesss
No not possible.
why? is are the holes not the same size? does it not bolt up the same? |
Not possible at all. Just get the JDM one if you can. The finish looks so much cleaner than the Metra. I mean it is all up to how you feel on quality too.
metra allows stock function, however the buttons cannot be removed. I hear the color match isn't 100 percent either.
looking to order a JDM control to replace my Metra controls, I believe mynismo has the JDM controls that will work, but they are $200
http://mynismo.com/products/?id=4343&rsku=19045 |
Why can't the rubber buttons be swapped out? Anyone ever try?
nobody has tried, you should, do a write up and take pics.
I checked with Metra tech support. They said it can't be done. I installed the kit and they don't look bad at all. Just like anything else in life, it's in the eyes of the beholder.
Even my picky wife is happy with it. |
thindle- can you please post pics? thanx!
do i need to buy a bracket to install the avic d3 with the metra dd kit? Thanx in advance for the help.
i'm using the bracket that the bose was in. it's not a perfect fit but i think it will work fine.
i used the DD kit from riverside. i only had to switch the dual AC button as the LED was already presoldered into the new circuit board |
Quick questions... why do you need the JDM climate control if you purchase the DD console alone?
| All times are GMT -4. The time now is 07:26 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
