G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Audio, Video & Electronics (https://g35driver.com/forums/audio-video-electronics-20/)
-   -   What's the power output from G35 battery? (https://g35driver.com/forums/audio-video-electronics/23911-whats-power-output-g35-battery.html)
tgenius May 7, 2004 12:14 AM
Has anyone used a multimeter to check what the battery is putting out?
2004 G35s 5AT DG/Graphite/Premium/Huper Optik Tint
ryoken May 7, 2004 02:42 AM
Re: What's the power output from G35 battery?
12 volts. [img]/w3timages/icons/smile.gif[/img]
I think you're interested in the alternator's output, which is 110 amps.
Batteries can push a lot of amps for a short period of time.. anywhere from 400 to 1000 to get a big motor started in the dead of winter. You don't want to count on that to run a radio with the engine off for a long time, though. Batteries have a rating called Reserve Capacity, usually about 2 hours. This is how long the battery can maintain 10.5 volts or more at 25 amps.. enough to keep the engine, headlights, defroster, wipers, etc. running if the alternator fails.
What are you trying to do?
https://g35driver.com/forums/attatch..._bannersig.jpg
g35mt May 7, 2004 02:46 AM
i think when the engine is not running, it is 12 volts. when the engine is running, it should be 12-14 volts.
g35mt
Meatshackle May 7, 2004 06:54 AM
I have a voltmeter hooked up to my system and when the car's running it's 14.1. Not running is 12.0.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
tgenius May 7, 2004 07:32 AM
14.1? BEAUTIFUL... that means the Alpine is running pretty close to spec (the #s are calculated based on 14.4V)
afr0puff May 7, 2004 09:46 AM
Lowest I've gotten was 11.8 when not running and highest 14.2 when running. On average, I get about 13.8.
http://www.anythingbox.net
ryoken May 7, 2004 11:00 AM
13.8 is what an alternator normally outputs.
tgenius May 7, 2004 11:14 AM
13.8 is actually pretty high.. I'm glad, that means I'm getting pretty close to the 14.4V that alpine specs their amps with.
GoldClam May 7, 2004 12:21 PM
I'm adding 2 amps, 1000.1 and a 600.4 Precision Power. My question is, will I need a more powerful battery or will the stock battery be ok? Last thing I want is to be stranded with a dead battery!!!
xswl0931 May 7, 2004 01:20 PM
My AVIC-N1 can tell me the voltage output. When engine is on, I get between 13.8 to 14.1 volts.
crashTestDummy May 7, 2004 01:53 PM
I concur.
DP G35 coupe/ AT / Prem graphite / Sport / Titanium 19 tint / 5 wire hyper-ground kit / clear corners / hyper white clearance/ i-Pod mini silver
San Diego, CA
RamboRami May 7, 2004 04:19 PM
ditto.
the avic-n1 manual says that the voltage should be between 12-15 with the engine running.
Of course when the engine is off, it will be around 12 and eventually go down to the 11's as you suck more juice you would think...
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
KPierson May 8, 2004 12:48 AM
Remember guys that instantanious battery voltage doesn't mean much when it comes to installing subwoofer amplifiers. The current draw from the amplifier will pull the voltage down.
Current output from the alternator is a much better spec to go with. We should have someone measure current draw while driving down the street, then it would be possilble to work backwards from the 110amps that was listed above to see if your electrical system is capable of handling the added load.
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
RE Short Shifter // Z Tube
ryoken May 8, 2004 12:20 PM
If you're putting in a big high-current system that requires more power, the battery won't be your problem.. you'll nead a heavy-duty alternator with a higher amp rating.
Think of electricity as a river.. voltage is the speed, and amps is how big (deep/wide) the river is. That's why high-current wires are bigger, and skinny wires will fry if you push too much current through them.
© 2026 MH Sub I, LLC dba Internet Brands
