I've got 2 Amps lying around... Need Advice!!!
I'm looking to make a few changes to the sound system in my car. I have two older amps i had used in past set-ups. Memphis PBC 4400 and a Rockford Power 800a4
I'm going to replace the front components with Infinity Kappa Perfect 6.5's the subs are 2 12" Kappa Perfects all from other set-ups the other speakers i'm not sure about yet. I just dont kknow which amp to keep and which to prolly give away at this point... Heeelp!!! |
Re: I've got 2 Amps lying around... Need Advice!!!
Any opinions?
bump... |
My opinion is that you give away the Memphis 4400.....to <strike>me</strike>Ryoken! :)
<font color=white>You hear a moderator whistling innocently in the corner. :-P</font color=white> 2004.5 Coupe/5AT/Ivory/Everything but chin spoiler/Z Tube-Popcharger/Crawford V5 Plenum on the way<P ID="edit"><FONT class="small"><EM>Edited by Ryoken on 05/13/04 05:21 AM.</EM></FONT></P> |
ROFL, Hey, Moderator abuse!!! :)
2004.5 Coupe/5AT/Ivory/Everything but chin spoiler/Z Tube-Popcharger/Crawford V5 Plenum on the way |
Where!?!
You should report that! [img]/w3timages/icons/tongue.gif[/img] https://g35driver.com/forums/attatch..._bannersig.jpg |
I didn't see or hear anything......What?
2003 TwBlue 5AT Sedan, sunroof, Graphite Leather, splashguards, HKS exhaust, 14 wire Grounding kit, 350Z duct, Stillen CAI Underbody rear diffusers, Drilled alum pedals |
well i think i'm gonna go with a D class amp to power the subs but will the Memphis (55w X 4) run the Kappas?
Rule of thumb I've read is run power at least 80% of the upper range at RMS which would mean you'd need to put 80 watts in those. I bet you could just run your factory Bose speakers pretty nicely with that and a new tweet.
| All times are GMT -4. The time now is 03:05 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
