Help my installer!
Old Oct 5, 2010 | 05:13 PM
theessence136's Avatar
Exclamation Help my installer!
Hey guys. I live in a small town and the only respectable installer has never done an '07+ G35 audio install (he has done an '05 before). I'm just getting 1 x 12 put in my trunk. My installer just called me and said that it's going to be way more complicated than he thought, and that he couldn't find any documentation on wiring from the head unit, and that everything was going through ribbon cables rather than separate wires. Do you guys have any resources that I can give him to ease this process at all? I don't have the Bose system fyi.
Thanks!
Old Oct 6, 2010 | 06:09 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
'07 Sedan or coupe? Bose or no Bose?
Old Oct 6, 2010 | 10:47 AM
It's an '07 sedan with no bose. He called me this morning to say he found the rear speaker outs and just needs to find a power for the amp still. You have diagrams?
Old Oct 6, 2010 | 11:30 AM
blazeplacid's Avatar
power for the amp should come straight from the battery and the ground should go to a chassis or frame ground
also, I dont like when a "pro" installer" has problems like this, it usually lead to more problems later.
Old Oct 6, 2010 | 12:09 PM
I meant the remote power on signal so the amp comes on when the stereo is on. If you can't tell, I don't know much of anything about car audio so I'm just going off what he said to me :-p
Yeah it kind of worries me too, but like I said I don't have much of a choice in my area. He does great work but he's never worked on this car before although he could have instilled a little more confidence...
Old Oct 6, 2010 | 02:42 PM
Just use the cigarette lighter for your amp power signal.
Blazeplacid is definitely right though, any "pro" installer who need help to install an amp needs to get kicked to the curb.
You're in New York, so you're what, like an hour away from real installers? Probably would have saved the time this guy was looking in the glove box for a signal cable.
Old Oct 7, 2010 | 04:11 PM
Nolimitmoto's Avatar
Thanks!
Ive been i the audio biz for more than 10 years and g35's are one of the easiest cars to do if that installer worked for me i would of fired him once he would of said something like that.
Old Oct 7, 2010 | 04:13 PM
12v from your battery. If you have bose you can get the remote and that line output from the rear in your trunk there is the amp on the drivers side and ground it to chassis and make sure he scuffs the metal.
Old Oct 7, 2010 | 04:29 PM
06g35meister's Avatar
remote turn on is blue with a silver stripe going into the amp in the same group with the HU->amp wires.
Old Oct 7, 2010 | 07:53 PM
He doesn't have Bose, so there's no remote turn on - hence the use of the cigarette lighter as the amp power signal wire.
Old Oct 9, 2010 | 08:43 PM
TPLGT's Avatar
Probably a dumb question but how do we know if we have Bose or not? I have an 07w/ Tech and Sport packages but there is no Bose found on the unit... the system sound OK but not as good as my wifes 06 Pathfinder with Bose writtenm all over everything...
Old Oct 9, 2010 | 09:13 PM
Usually it will say Bose all over everything. Speakers, grills, radio, etc
Old Oct 9, 2010 | 09:20 PM
TPLGT's Avatar
I just looked...says Bose on the center speaker on the rear deck lid. Thats it...
Old Oct 10, 2010 | 12:07 AM
hey...uh...you need to find a new installer
its the bose system and I can tell that from a computer and I have never seen your car
your installer is right there and cant tell????
Old Oct 12, 2010 | 04:12 PM
saywat?'s Avatar
wow wat a ****ty installer. he shouldnt even be doing installs for people. ur installer is pretty useless ur better off googling for info and doing it urself. btw please have ur installer read our comments lol
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
