A MASSIVE TRIBUTE TO 4080's SKILLS! WELL DONE 4080! TAKE A BOW!
Dec 21, 2004 | 10:16 PM
sorry, here is the pic
Reply 0
Dec 21, 2004 | 10:18 PM
Quote: hey 4080 those are really nice enclosures. I remember reading somewhere that you had an enclosure that fitted 2 8 inch subs...or somethin like that...so is this correct? I wouldnt want 2 8w7's...I want 2 koda 8's or 2 id8's or 2 re8's...something along that line...let me know what you think about the pair of 8's....SQ is definately more important to me...I have a 13 kv2 in a sealed box and had it crossed at 40 hz on my 500/1 and didnt like the lows much because it over powers my speakers too much and found out that I like it much more crossed at 65 or 70 hz or somethin...so you have any suggestions? thanks man...
No sorry, only for one 8" ported or one 10" sealed.
4080
Reply 0
Apr 11, 2005 | 06:31 AM
8" and a 10"
Quote: No sorry, only for one 8" ported or one 10" sealed.
4080
hey, has anyone installed both a 8" ported and a 10" sealed together in the same trunk?? wouldn't that give you best of both worlds........deeper sound from ported and tighter controlled from the sealed. right? or would the soundwaves be crashing into each other and #%^@&# things up? just curious?????????????
thx!
Reply 0
Apr 11, 2005 | 12:19 PM
I will also say it definitely does work with the cargo net. Also I really like the 4080 enclosure. Even the installer said this is one helluva enclosure. Fit perfectly with some force used which is a sign its custom made. Strong and durable. Only problem I have is with the mesh cover comes off regularly. Probably because of me hitting the bass pretty good I think.
Reply 0
Apr 11, 2005 | 08:20 PM
Quote: I will also say it definitely does work with the cargo net. Also I really like the 4080 enclosure. Even the installer said this is one helluva enclosure. Fit perfectly with some force used which is a sign its custom made. Strong and durable. Only problem I have is with the mesh cover comes off regularly. Probably because of me hitting the bass pretty good I think.
I need to get you a new grill if that one is having trouble staying on. PM to remind me.
4080
Reply 0
Apr 11, 2005 | 10:29 PM
so will this box fit any 10 inch speaker, even the Kicker Solo-Baric L7 S10L74, if so how much are these boxes???
Reply 0
Apr 11, 2005 | 10:38 PM
Quote: so will this box fit any 10 inch speaker, even the Kicker Solo-Baric L7 S10L74, if so how much are these boxes???
Aren't Solo-Baric's square? If so it won't fit unless 4080 does custom ones for that but I don't think so. Either way pm him and he will get you a price
Reply 0
Apr 12, 2005 | 10:50 PM
Quote: Aren't Solo-Baric's square? If so it won't fit unless 4080 does custom ones for that but I don't think so. Either way pm him and he will get you a price
Sorry, no square woofers.
Reply 0
Apr 14, 2005 | 02:29 AM
There are much better subs than the Kicker's at that price range anyways. I would decide how important this box is to you first. Then decided what sub to use with it.
If you are sold on the kicker, then you might be missing out on a great enclosure. Depends on your priorities.
Reply 0
