Layering wheel control innerface
Hi I have the steering wheel control interface I just wanted to know WHERE am I connecting that harness tot the 2005 g35 metra harness?i didn't previously have bluetooth BUT IM NOT UNDERSTANDING HOW TO CONNECT THE CONTROLLER AND I AM IN THE MIDDLE OF INSTALL.
Thx |
Originally Posted by Alexus-Kia
(Post 6955057)
Thx https://lh3.googleusercontent.com/-v...Identified.png |
Aaronhl's post is how I did mine. Quick, easy, and works great. And like Wraternaut said, connect to the head unit harness for power and ground.
Originally Posted by AARONHL
(Post 6278497)
The ASWC is a pretty easy installation. I plugged the 3.5mm wire into the wrong plug on my headunit and found that to be the problem hours later. So, make sure all your connections are correct. It's a good idea to use the headunit's plug and not hard to make. The hardest part is taking it off the circuit board. Pictures below to show how easy it is.
Once you have all your connections and double checked them, turn the ignition to "ON", after hold the VOLUME UP BUTTON (on the steering wheel) until the red light on the ASWC stops blinking. Your wheel controls should be working after it continues to blink for a few seconds. http://img.photobucket.com/albums/v6...l/IMG_2248.jpg http://img.photobucket.com/albums/v6...l/IMG_2249.jpg This is the direction shown in "Silver tiburon's" post on Page 1. http://img.photobucket.com/albums/v6...l/IMG_2255.jpg http://img.photobucket.com/albums/v6...l/IMG_2253.jpg http://img.photobucket.com/albums/v6...l/IMG_2258.jpg http://img.photobucket.com/albums/v6...l/IMG_2262.jpg http://img.photobucket.com/albums/v6...l/IMG_2264.jpg And then stuff everything on the lower left side. I have the PAC, steering, and bypass harnesses stuffed down there: http://img.photobucket.com/albums/v6...l/IMG_2266.jpg |
