Is there any way to access iPOD/AUX box without removing AC/Radio on a 05 AT G35x?
Hi All,
I just bought my first G (a 2005 G35x). I've been reading through the forums for a few weeks now, and I wanted first to say thanks! There's a ton of great information and I appreciate the effort that the members have put into long tutorial write-ups. Currently, I would like to install bluetooth call handling and music streaming into this car. In my old car, I had an aftermarket HU and it was easy to install but I've learned over the last few weeks that it's not so simple with a G35x: to install a HU you have to buy the JDM/Metra kit. Besides having to pay 300+/150+ respectively for the double din AC kits, I'd also have to cut into the wood trim, which I believe a member has done (but I'm not a pro like him/her!) Thus, I've arrived at the conclusion that I need to install a GROM bluetooth kit. It sounds like USA-SPEC doesn't have a compatible Bluetooth kit for the 05 G35x. The car has an AUX cable and iPod cable located beneath the 12V socket below the center armrest (next to the coin tray, not the ashtray). I watched Wrathernaut's YouTube video re: removing the center console, removed the entire assembly piece for the armrest + cupholders, and removed the plate underneath the shift knob. I noticed that the 2 cords (AUX/iPOD) ran into the center console behind the AC/Radio. I am able to access the AUX input via the radio button on my stereo. I found, in another thread, that the 06 G35 SAT radio harness is "located under the rear package tray on the passenger side" (credit: Mustang 5L5). Is it possible that, on the 05 G35x, the SAT radio harness is also located under the rear package tray, and if so, can I access it without removing the AC/radio? Ultimately, I'd like to take a look at it to determine whether I need to buy a new box entirely or whether I can just add a bluetooth microphone/dongle to it. Anyway, thanks so much for reading! Sorry if I missed a thread dedicated to this problem - I tried to read as much as I could! |
In a 2005 G35, the SAT cable is behind the rear seat on the passenger side. If you remove the trim from the trunk up against the seats, you will find it there.
However, it's a factory-specific connector, and AFAIK, only the OEM at radio or OEM nissan Ipod kit will connect to it. |
Originally Posted by Mustang5L5
(Post 6967810)
However, it's a factory-specific connector, and AFAIK, only the OEM at radio or OEM nissan Ipod kit will connect to it. Does this mean I'd be unable to take that out and swap in a GROM Audio box such as the following? http://www.gromaudio.com/store/usb_a...interface.html |
Originally Posted by djtalon
(Post 6967849)
I presume it's the USA SPEC PA15-INFI box that I currently have? I just read in another thread that Wrathernaut commented that the G35's with wood trim are USA SPEC...
Does this mean I'd be unable to take that out and swap in a GROM Audio box such as the following? http://www.gromaudio.com/store/usb_a...interface.html https://g35driver.com/forums/audio-v...ory-radio.html Thanks! |
Looking to do the same thing to my 05 sedan...keep me updated on your experience with the install and quality of the Grom adapter/bluetooth quality.
Thanks |
(Post 6967849)
Does this mean I'd be unable to take that out and swap in a GROM Audio box such as the following? http://www.gromaudio.com/store/usb_a...interface.html If it's plugged into the back of the radio, and has an iPod connection, it's most likely the USASPEC PA15-NIS, or PAC ISNI571, they're functionally the same, and both connect to the back of the radio. The PA15-INFI connects to the satellite harness at the trunk. The GROM connects to the back of the radio, so you'd have to remove the radio and remove the old adapter to put in the GROM. |
Originally Posted by Wrathernaut
(Post 6967969)
Just for clarification (for others who may be checking this thread).
Originally Posted by RedBeauty84ZX
(Post 6967995)
Is there a preference or consensus as to which of the two is better for our cars?
(Post 6967969)
djtalon,
I will be following in your foot steps in the next few weeks so any documentation on your experience would greatly be appreciated! Any particular reason you chose the Grom over the Audiovox(Dice) option? Both offer Bluetooth and similar capabilities from what I can see. |
(Post 6968034)
djtalon,
I will be following in your foot steps in the next few weeks so any documentation on your experience would greatly be appreciated! Any particular reason you chose the Grom over the Audiovox(Dice) option? Both offer Bluetooth and similar capabilities from what I can see. This is the Wrathernaut center console removal video to which I was referring earlier. It's terrific: And these are probably the most useful threads I've found: https://g35driver.com/forums/audio-v...ory-radio.html https://g35driver.com/forums/audio-v...x-install.html This is the device I bought: http://www.newegg.com/Product/Produc...0092-_-Product I anticipate it will be here in about a week or so. I'll keep you posted. |
(Post 6968093)
Frankly, RedBeauty84ZX, I didn't really consider the Audiovox. First, from all of the forum threads I read on this site, it seemed like most people have either USA SPEC or GROM boxes. I figure I'd prefer to own a solution that is widely owned so that, if I run into issues, others have as well. So TBH I don't know anything about Audiovox except that it seems like fewer people own it.
This is the Wrathernaut center console removal video to which I was referring earlier. It's terrific: 2005 - 2007 G35 Radio Removal - YouTube And these are probably the most useful threads I've found: https://g35driver.com/forums/audio-v...ory-radio.html https://g35driver.com/forums/audio-v...x-install.html This is the device I bought: http://www.newegg.com/Product/Produc...0092-_-Product I anticipate it will be here in about a week or so. I'll keep you posted. Trying to decide where the best play to install the Bluetooth Mic will be. Also wondering if you can use a different mic than the one supplied from Grom as their mic isn't the prettiest. |
The video is ok, and I may be biased, but I'd follow my guide for removing the radio, the way he removes the upper clock trim has potential to break the little plastic tabs and permanently make the top piece wobbly.
The GROM bluetooth microphone is a standard mono channel mic with a 3.5mm plug, so you've got any number of microphones to choose from. I used a garmin external microphone for my install over the factory Pioneer microhpones, but they use a 2.5mm plug. As for bluetooth mic placement, I've been wanting to hook up a microphone to a decibel meter and test multiple locations for the absolute least wind/road noise location, but I'm pretty sure (near) the factory bluetooth mic location is best. I tried in the cash cluster, but anytime you make a turn and your hands or the steering wheel go in front of it, it goes super quiet on the other end. I also tried the upper corner by the sun visor, but there's more wind noise there than the center mount I ended with: https://cimg1.ibsrv.net/gimg/g35driv...cc22034579.jpg |
Wrathernaut, is that where your microphone is currently? Next to the drop down sunglasses holder?
Yep.
I do calls on the freeway @ 75mph frequently, no complaints. |
