Aux in g35 coupe
Is it possible to splice the cd wire, and connect it with a aux. so when I press the cd button it will just play the aux?
Originally Posted by FRUG35
(Post 7024539)
If you're handy with a soldering pen, you could fairly easily replace the analog audio signal from the CD reader with your own wires (if it ever goes through wires) and a bit more difficult, but still possible, if it goes through a pathway on the board itself, but you'd be guessing at proper signal levels so as not to overload the audio processor. Check the linked schematic in the first post of this thread: https://g35driver.com/forums/audio-v...epair-diy.html and you might be able to spot a good spot. |
