Climate control / head unit in constant dim state after stereo installl
I recently installed a pioneer double DIN unit in my 04 6mt coupe. I’m a little perplexed by the problem I’m having...
The climate control readout/compass and head unit are in a constant dimmed state, but the gauge cluster is fully lit till the stalk is set to have the headlights on. My running lights are constantly on also, till I shut the car off. I installed everything as described in the write up by wrathernaught pinned above.
Using a metra kit, pac rom nis2, and metra aswc1. Once I remove power from the head unit by unplugging the harness, it will go back to normal. I’ve also tried depinning the dimmer wire and pulling switched power from the cigar lighter, all to no avail.
Has anyone else experienced this? Appreciate any/all help.
*edit* I should also mention that when the car is off, no key in ignition, and the stalk is turned to headlamps on, the radio will turn on also.
I will go over the wiring once again. I depinned the orange dimmer/illumination wire from the pac harness and still had the same problem though. I really appreciate you taking the time to offer some assistance. I’ll post up if I find anything new. 👍
Unplug the harness for the radio from the factory plugs completely and see if the dimming is still weird.
