G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Audio, Video & Electronics (https://g35driver.com/forums/audio-video-electronics-20/)
-   -   Ac stuck on 74 and radio don't work . (https://g35driver.com/forums/audio-video-electronics/462670-ac-stuck-74-radio-dont-work.html)
Rick Nanez Feb 21, 2018 11:03 PM
if I put in new after market radio will this fix problem with ac or will I have to do something else? Thanks
Scorpi0 Feb 22, 2018 02:50 AM
[LEFT]https://g35driver.com/forums/audio-v...epair-diy.html
U can also search this issue on google. Its a common problem and there are hundreds of threads about it.
Easiest fix is to replace the entire AC/Stereo unit. Its all one piece. **************************************************/LEFT]
Scorpi0 Feb 22, 2018 02:52 AM
Blue Dream Feb 22, 2018 07:42 AM
Rick I know you're new but please make sure you post new threads in the appropriate place. The forum you put this is specifically saye "No car questions" in the header. That being said I've moved this to the right place and reading through this forum you'll see that your issue is very common. Best solution is to buy an aftermarket DD face plate and stereo unit and replace the whole stock assembly. It seems that the majority of stock stereos in the 03-06 sedans and 03-07 coupes will have radio failure at some point in their lives so we don't recommend buying another OEM unit.
fulanoderock Feb 22, 2018 11:14 PM
I had the same issues a couple months ago. I replaced the oem unit with a Sony Bluetooth unit that also provides hands free calling. Best upgrade ever man. Best Buy installed it for 50 or so and i provided the equipment I bought from internet.
© 2026 MH Sub I, LLC dba Internet Brands
