G35 2006 Sedan Bose Subwoofer Help
I ran a subwoofer and amp and the installer used a Line out converter, tapped into the factory sub to get a signal but I removed my system and connected the 2 wires that he cut ,but when I reconnect back the sub speaker wires "black/white" it's like the sub barely moves there is power just not that boom I once had l, can anyone help me thank
Maybe is the subwoofer went bad? Worked flawless before the LOC |
Anyone?
U sure u hooked up the correct wires back to the sub? Something tells me u didnt. |
1 Attachment(s)
Originally Posted by Scorpi0
(Post 7141482)
U sure u hooked up the correct wires back to the sub? Something tells me u didnt. Here's a picture bro I reconnected back the wires that was cut black connected with black and white with white |
What did you connect them together with? Solder? Crimp? It looks like you hand-twisted them together and placed a piece of electrical tape over the top which isn't going to work because it's just hopes and dreams holding those wires together.
(Post 7141503)
I made sure and twisted them properly not poorly ,equal cuts and twisted good |
U have tried messing with the stereo settings? |
Originally Posted by SilverSurfer01
(Post 7141519)
(Post 7141528)
What I'm saying though is you need to have your wires MECHANICALLY fastened together, either with solder, a crimp, heck even a wirenut if that's all you have. A twisted connection like that is NEVER going to hold trust me. Stranded wire unravels almost immediately, it won't matter if you have it taped there needs to be somethings physically mating the wire together.
Properly twisted wires will hold together forever unless something pulls it apart. |
Lol no it won't, I do this for a living, I give it a month or two MAX, in worst case it might only hold a week. You need something to BOND the circuit or you will have either very high resistance or very low surface area. One will give a poor/weak signal, the other will generate excess heat.
(Post 7141611)
So I got the sub to play but it doesn't sound the same ,compare to when it wasn't cut I'll take your advice and have it solder |
(Post 7141611)
(Post 7141613)
(Post 7141623)
How different is the sound? I hear the sub sounds good at low volume but when I raise the volume higher doesn't sound as deep off a bass it once had maybe it's the connection? It needs to be solder by the way my radio is a pioneer 490BS |
Maybe your ears just got used to your previous system? If youre 100% sure u have the system back to original then I would assume its just a matter of getting the settings right. |
