Dynamat
anyone can give me a general cost to have the g35 coupe trunk done in dynamat? Thanks |
Don't. Dynamat is poor quality vibration dampener. Go with 25% coverage with a quality vibration dampener (https://www.sounddeadenershowdown.co...tiles%E2%84%A2) and you're good to go. It's super easy DIY, so just pick up 20 or so tiles and don't overdo it. Get some on the door skins too. Mine have lasted about 10years now in Hawaii, Georgia and Arizona heat.
Originally Posted by Wrathernaut
(Post 7159271)
Thank you for the advice I just ordered 20 tiles for the trunk I’ll eventually do the doors too, having them spaced out like that is more effective then covering the whole trunk? |
Originally Posted by Albanian122
(Post 7159287)
(Post 7159309)
Vibration dampener doesn't need to be 100% coverage; there's a lot of information on the SDS site that is worth reading. You can add some closed cell foam and MLV later if you want later.
are there any recommended installers for SDS in the tri state |
the sds is super simple to install, just cut pieces of it and use it sparingly in the middle of a large flat panel that has the possibility of resonating. its not like dynamat where you want to cover the entire thing. just rip off the trim panels and start applying the squares. theres a lot of info on the sds site and its pretty good. i bought a bunch of mlv and did the whole shabang when i did my interior. get the foam, the mlv and the tiles and your car will sound like a coffin
but at the same time if you dont have the time and have the money and would rather go that route im sure any kind of audio installer will be able to help you out. its a very simple process |
